Revisit old topic Valve rattle/ Engine ping ( HEEELLPPP) - Mustang Evolution
Old 09-21-2016, 06:41 AM   #1
Jar72's Avatar
I am revisiting an old topic and wanted some fresh info. It’s a bit long but I want to make sure to pre answer any questions and give the correct info right off to avoid well some rather off the wall advice about a car I used to own. HAHA Here is a short rundown and what I’ve learned.
Car: 06 GT
Mods: Air raid race CAI Bama XCT tuner Pypes Violator Mufflers
Problem: Nasty ping / rattle ( sounds like marbles in a mason jar or sounds like a chain link fence being shook)
Occurrences: This is tricky on eco tune with 87 octane fuel it does it at about 1/4 to 1/2 throttle and scares the hell out of me.
Eco tune 93 octane much better but does it at 1/2 to 3/4 under load (accelerating a little more than needed in town) on the highway if I open her up like passing a semi solid 1/2 to 3/4 throttle loaded. It’s a bit more pronounced.
From a dead stop I can make a solid run as long as I don’t go past 3/4. It will ping very slightly when shifting
The worst moment-----full throttle lay out rolling start 5 mph I have to let off before it shifts only due to it sounding like it’s about to explode.
I have data logged it twice and nothing strange shows up.
I read up on gas/ ethanol/ non ethanol I’ve tried them all its still there.
I did read that the modulars have some issues and that this is one but I have not found any one that has it this bad nor that there has been a fix.
I also read that the CAI could have turbulence at the MAF causing a bad fuel mix.
Dropping the T stat 10 Deg will help lower temp and help with detonation.
I would love to get it on a dyno and have a professional diagnos it. doesnt seem to be one around here ( South GA) that i can afford. $500 to get it on.
JMF
Jar72 is offline   Reply With Quote
Old 09-22-2016, 05:50 PM   #2
Jar72's Avatar
Anyone
JMF
Old 09-23-2016, 10:30 AM   #3
I know you said that you datalogged it it twice, but have you sent those datalogs to Bama tier 2 support, and described your problem to them? They may be able to write a better tune for you - I would try that if you haven't already.
KevinP is offline   Reply With Quote
Old 09-24-2016, 11:39 AM   #4
Jar72's Avatar
Ok that's a good suggestion. Thanks I know last year when I got the second tune from them I told them I had a datalog. Didn't seem to want it though.
JMF
Old 09-24-2016, 07:48 PM   #5
detonation?
Current: 2007 GTCS
*Killer Chiller
*Roush> Supercharger, Suspension, Intake
*Exhaust> UPR OR, Borla Touring
*2.49 Pulley
*3:73 FR
M90CaliSpecial is offline   Reply With Quote
Old 09-25-2016, 11:00 AM   #6
Process of elimination. Remove the tune? Remove the CAI?
sleeper is offline   Reply With Quote
Old 09-26-2016, 12:51 PM   #7
Jar72's Avatar
Don't have stock one and the car wont run on stock tune with this cai. Great idea though.
JMF
Old 09-26-2016, 01:06 PM   #8
In that case, IMHO, getting a professional diagnosis is a whole lot cheaper that having to replace an engine.
Old 09-26-2016, 06:55 PM   #9
It really does sound like a tune problem to me and if he already has Bama Tunes for Life then it's something that he can try essentially for free (excluding the time commitment).
Old 09-27-2016, 09:26 AM   #10
Jar72's Avatar
Originally Posted by M90CaliSpecial View Post
detonation?
Yes detonation. At least that what it reminds me of. In my other cars and trucks In The past it was simply messing with the timing and carb mixes. This is a whole new thing. I have had a detune done less timing etc. did not really change anything.
JMF
Old 09-27-2016, 09:39 AM   #11
Maybe your problem is pre-ignition, hot spark plugs maybe, try colder plugs. Also try running race fuel to see if that improves it or Torco additive.
Old 09-28-2016, 01:25 AM   #12
irishn8's Avatar
Like sleeper said, try racing fuel. If the sound doesn't go away or at least change then its not detonation.
Old 09-29-2016, 11:03 AM   #13
Jar72's Avatar
A little update from yet more research. so this actually makes sense for the most part on the 3/4 to WOT. My stock Maf is pegging and cant read the extra airflow. the reason i think this might be a major player in my issue is that. my buddy stood next to the car the other day and i laid her out out 3/4 throttle from a stop. He said each time it got into the higher RPM range is sounded different almost like it was running lean. SOOO i looked into the Race CAI I have on it and their is a restriction adapter that comes with regular CAI for the stock MAF. Option A i get the restriction tube cheaper/ option B i save up for the Granatelli performance MAF sensor. And why doesnt American Muscle put this in the product description Id a bout the other and save up for the new maf. I like B but dang this car is costing me a fortune in bits and pieces had to replace the fuel pump recently that was 300 and i did it myself.
JMF
Old 09-29-2016, 11:10 AM   #14
What's the cost difference? I would get the restriction adapter if it's significantly cheaper and you are not certain that it is actually the problem. If that fixes it, maybe save up for the other CAI and sell your old one on ebay or craigslist or on this site after you install the new one. First thing is to stop your engine from pinging though.
Old 09-30-2016, 03:54 AM   #15
Jar72's Avatar
I was thinking that last night as well. I'm trying to find the peice seperate. From the kit once I find it I'll pass it on.
JMF
Old 11-15-2016, 07:57 AM   #16
Jar72's Avatar
Update on this. After much more research. I found a TSB for the modular motor in a truck that states to change to 5 w30 synthetic. I asked the local service mgr about it. He did some research as well. And agreed that if it's good for the truck motor it should be the same for the mustang. So switched to 5 30 synth. And behold no ping. Well I do get a very very minor ping if I'm running at highway speed and hammer it. But it's only for a split second. Dead stop full throttle no ping.
JMF
Power loss revisit FirstGeneration 2011-2014 Mustang GT 3 03-07-2016 12:59 PM
Valve rattle/ Ping Jar72 2005-2010 Mustang GT 17 11-18-2015 10:08 AM
03 Mach Engine ping or knock MajorPain999 1996-2004 Mustang GT 3 04-10-2013 09:03 PM
Engine "ping" Eeyore General Mustang Discussion 6 04-26-2009 03:07 PM
Revisit!!! Ugliest stang pic Danger Dude The Bar 32 04-02-2005 05:39 AM
04:26 AM
