Bama tune check engine light - Mustang Evolution
Old 09-29-2016, 05:29 PM   #1
XSlashDashX's Avatar
I just install my jlt series 3 intake and I ran bama 87 tune until I ran out of gas and switched to my 93 race tune. Now check engine light came on for 3 codes. 2 misfires now. Prior before all this I had no codes on other then the no catalyst code.
Old 09-29-2016, 06:18 PM   #2
Revvv's Avatar
You may have fouled plugs or a bad coil. Clear the codes and see whether or not the codes return.
Old 09-29-2016, 07:32 PM   #3
Yeah, I cleared the codes and I sit at idle reving to 2k rpms and the check engine light start flashing and went off. No stored codes though. Haven't driven it yet though.
Old 09-29-2016, 07:55 PM   #4
Contact Bama and ask them for a new tune. If they don't know what the problem is, you can datalog the car and send them the details for fine tuning.
Also, did you try to put the 87 octane tune back on to see if the tune is the problem and not something else? You can run an 87 octane tune with 93 octane gas, just not the other way around.
KevinP is offline   Reply With Quote
Old 09-29-2016, 08:24 PM   #5
Didn't know that. I'll try out the 87 tune again. The first time I use the 87 tune was fine. I'll reflash it back tomorrow and see how it goes.
Old 09-29-2016, 08:45 PM   #6
Based on what you're describing, your problem began after you did 2 things:
1. uploaded a new tune
2. added new gas
I would check the tune first, since (at least to me) that sounds like the most likely problem. The second thing I would check is your gas receipt to make sure you purchased 93 octane gas and not some other grade just to be sure - you would not be the first person to make that mistake.
Third, I guess, would be to believe that maybe you got a bad tank of gas? I have heard of that happening but I think it's a bit too coincidental to believe that's the problem right off the bat.
Old 09-29-2016, 08:50 PM   #7
2. added new gas
Haha, yeah it's 93 Octane for sure. Either bad gas or tune. Will find out tomorrow.
Old 09-30-2016, 11:30 AM   #8
So I drove at least 25 miles on the 87 tune and no codes pop up. Emailed bama and they want to datalog the 93 tune to see the problem.
Old 09-30-2016, 11:36 AM   #9
Awesome. That's happened to me once before, except different. For me, their system that is used to generate the tunes reads that my 2007 GT comes with 3.31 gears but mine actually came with the 3.55 gear setup from the factory. Once we figured this out, it was as easy as them just updating the gear ratio and I was good to go. Amazing how much the gear ratio screws up the way the car runs. Good luck with the tune!
Old 09-30-2016, 12:54 PM   #10
I notice my spark advance was going up to 35 on 93 tune. Is that normal? Seems high.
Old 09-30-2016, 12:56 PM   #11
C013RA's Avatar
Did they send you a tune with corrected ratios, or did they tell you where to change it? A wrong gear ratio setting should only affect your spedometer.
Had 5 Mustangs. the last two were a Black 2012 GT/CS lowered, custom wheels, Airaid CAI, Flowmaster Outlaws, BAMA tune, MMD hood struts, Raxiom Black Halo headlights, 13-14 tail lights, & Raxiom Taillight adapters. Removed the 2012 GT/CS stripe (black on black sucks) Replaced with 13-14 Silver GT/CS stripes. I now have a 2015 Magnetic Gray Premium GT with Performance Pack, Borla's, Velgen 20" wheels with Nitto Invos with 275's up front,and 295's in the rear. Airaid CAI, JLT oil separator.
C013RA is offline   Reply With Quote
Old 10-01-2016, 11:11 AM   #12
They sent a new tune. The wrong gear ratios were causing the idle to dip to about 500 rpms each time I took the car out of gear.
Old 10-01-2016, 05:42 PM   #13
MustangLover69's Avatar
Thats not good get a code reader it will help
MustangLover69 is offline   Reply With Quote
Old 10-01-2016, 06:43 PM   #14
Grabber Blue5.0's Avatar
The tuner can read codes.
check engine
Bama Tune and check engine ? larietrope 2011-2014 Mustang GT 20 12-04-2013 12:18 AM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 06:26 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 11:45 AM
Boss 302 tune and check engine light 4968coyote General Mustang Discussion 0 11-05-2012 11:53 AM
check engine light after x pipe and tune. Yellow50 2011-2014 Mustang GT 21 05-14-2012 10:59 PM
12:33 AM
