Rear end slide.... - Mustang Evolution
Old 12-24-2016, 07:15 PM   #1
fensket's Avatar
Region: Arkansas
Rear end slide....
I was driving home from the airport today after getting my plane tickets for Christmas. I went to pass someone and my rear end started to fishtail from side to side. My brothers and I thought I might have had a blowout when I got under the car I saw that one of the suspension components, a bar that was suppose to be solid behind the sway bar but in front of the rear end pumpkin was broken into two pieces. What exactly is this part? The Panhard bar?
fensket is offline   Reply With Quote
Old 12-24-2016, 07:48 PM   #2
In the position of this red bar?
Name:	ImageUploadedByMustang Evolution1482630489.165561.jpg
If yes it's your Panhard bar.
Pick your poison.
Old 12-24-2016, 07:53 PM   #3
fensket's Avatar
Region: Arkansas
Attachment 212977
Pick your poison.
It is going straight across instead of diagonally across. Well it's now snapped in the center but on each side it is level on each side
Old 12-24-2016, 07:58 PM   #4
Can post a picture of it?
That'd be the easiest way to tell what it is.
Pick your poison.
Old 12-24-2016, 08:00 PM   #5
fensket's Avatar
Region: Arkansas
Pick your poison.
Old 12-24-2016, 08:05 PM   #6
Rear end slide....
That's the Panhard bar.
Pick your poison.
Old 12-24-2016, 08:08 PM   #7
fensket's Avatar
Region: Arkansas
Thank you. From what I could determine from other pictures I gathered the same. I ordered a BMR non-adjustable Panhard bar from American Muscle just a little bit ago.
Old 12-24-2016, 08:11 PM   #8
That's a good one. Now if you plan on lowering the car at a certain point you'll need an adjustable Panhard bar to correct the misalignment of the rear end. One side will stick out and the other pushed in. I needed an adjustable one with a 1.75in lower in the rear.
Pick your poison.
Old 12-24-2016, 08:19 PM   #9
fensket's Avatar
Region: Arkansas
Thank you sir. Right now I'm just keeping everything as stock as I can until it's paid off then the fun will begin. I'all be sure to keep that in mind wen I get to that point. The only mods on my car at this time are Pypes twin mid length mufflers, some light modifications since I'm a fire fighter and Probation officer, and royal purple running through its veins everywhere.
Old 12-24-2016, 08:33 PM   #10
Need any more info you know where we are.
Pick your poison.
Old 12-24-2016, 08:42 PM   #11
fensket's Avatar
Region: Arkansas
Pick your poison.
Thank you sir. I definitely will. I've been floating around on here since I got my mustang in 2015. Just been looking at ideas and whatnot. I did give an introduction in the intro section.
Old 01-03-2017, 09:57 PM   #12
fensket's Avatar
Region: Arkansas
Rear end slide....
Well, I finally got the BMR bar installed and what a difference did it make. No more rear end slide. The factory bar had no grease fittings at all and the bushings were completely shot when it snapped. I'll attached a few pictures here.
Name:	ImageUploadedByMustang Evolution1483502186.869710.jpg
ID:	214034   Click image for larger version
Name:	ImageUploadedByMustang Evolution1483502225.966723.jpg
Old 01-04-2017, 12:04 AM   #13
GrnGT's Avatar
I've never seen one snap before. That's crazy.
GrnGT is offline   Reply With Quote
Old 01-04-2017, 09:04 AM   #14
fensket's Avatar
Region: Arkansas
Well the car is nearing 100,000 miles plus it doesn't help that my car gets best to hell by me when I have to get to the firehouse fast.
Old 01-04-2017, 09:19 AM   #15
GrnGT's Avatar
That would do it.
Okay Get a Your Slide Rules Out Landspeedracer 1996-2004 Mustang GT 4 12-20-2014 05:11 AM
First Mustang Slide Show Soccerluvr4 Pictures and Videos 2 02-28-2013 09:45 PM
Rear end Jbeas50 1979-1995 Mustang GT 7 05-23-2012 03:22 PM
Brand new 2010 Mustang Gt...and the Passenger seat won't slide Wolfhawk46 2011-2014 Mustang GT 5 03-19-2010 11:43 AM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 04:43 AM
05:46 PM
