'07 GT Ragtop-couple questions - Mustang Evolution
Old 08-12-2008, 06:20 AM   #1
Question '07 GT Ragtop-couple questions
I just picked up a used '07 GT 'vert with 12K miles & auto. transmission-all stock car.
Notice at 35mph (1200-1300 rpm) a resonating that when either below that speed or above is not present.
Anyone else experience something similar? If so, what may be the cause & solution other than not driving at that speed & rpm range?
Will be taking it in to a local dealer for a couple things to get looked at-check for the TSB's on the convertible top wear and cables(don't hear any rattles at the front of the top, at least not yet.)
Anyone else notice or hear some "creaking" or light clunking noise from the rear of the vehicle-mainly noticed when going in and out of driveways.
rikstang is offline   Reply With Quote
Old 08-12-2008, 08:10 AM   #2
Re: '07 GT Ragtop-couple questions
the issue at 35mph might be the tires out of balance~ if it goes away after a certian range of mph it could be this.
Ive not heard anything on the tops and wear
creaking is the rear solid axle twisting, there are rubber bushings in there and it moves side to side~ you can lube them up but its not going to get much better.
Old 08-12-2008, 11:53 AM   #3
The vibration/resonation is noticeable even when stopped and you increase/decrease the engine rpm through the 1200-1300 range so it wouldn't be tire-related.
The technical service bulletin for the top wear is # 06-22-16 and may affect convertible's built prior to 12/2006. (I'll see if I can post the actual tsb.)
Old 08-12-2008, 03:09 PM   #4
the 05&^ cars have a panhard bar, they arent like the 04 gts, the axle cant move side to side, and i havent heard of the bushings making noise, could be something else.
SimplyOrange is offline   Reply With Quote
Old 08-12-2008, 03:56 PM   #5
Send a message via AIM to Mustang GT HO
Man us 04 owners got shafted.
2004 GT- K&N CAI, 15% Tint, Borla Catback
Mustang GT HO is offline   Reply With Quote
Old 08-22-2008, 11:19 AM   #6
The resonating is caused by the exhaust pipe hangers located on the cross member under the transmission. They are there to hold up the pipes during engine installation at the factory and serve no other purpose (except to create vibration). There's a TSB on this. It says to cut off the hangers and bend the rod on the pipe upward. I just cut off the hangers myself with a hacksaw and left the rods where they were. No resonating/vibration since.
illini4 is offline   Reply With Quote
Old 08-22-2008, 01:20 PM   #7
Thanks Illini4. I should have followed up on this in that I had the local dealer check it out and they performed the TSB 08-3-4 on my car and that problem is GONE!
Old 08-26-2008, 07:58 AM   #8
Region: Arkansas
Dang, I will have to check mine for that. I just write off the resonation to the Pypes Violator Axle-back.
fear1 is offline   Reply With Quote
Old 09-05-2008, 08:19 AM   #9
Region: Arkansas
On my 07, the hangers are in the rubber insulators that are attached to the trans crossmember.
Old 10-07-2008, 11:52 AM   #10
The rubber insulators are inside the hangers I'm referring to. Cut through the hangers, then remove them from the cross member (they are attached with tabs sticking in slots) and the rubber pieces. The rods on the pipes can be left where they are.
Old 10-07-2008, 11:58 AM   #11
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
i'm having that problem of noise in my car. to stubborn and lazy to take it to the dealership. :\ time to bust out the hack saw :whistle:
05 Stang to the Bang! X-Pipe, Headers, Stage 2 Roush Kit, Tuner, JBA Exhaust and about a million and 4 Horsepower.
braumab is offline   Reply With Quote
Old 10-07-2008, 12:00 PM   #12
Region: Arkansas
Guess it is time to plug in the sawzall.
Old 10-07-2008, 01:24 PM   #13
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
And on the seventh day, God rested because he had a sawzall as opposed to a hacksaw . . . and it was good
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 10-07-2008, 03:05 PM   #14
braumab's Avatar
Region: Arkansas
lol....
Old 10-08-2008, 07:28 AM   #15
Region: Arkansas
Preach on brother!!!
couple of questions mustang0386 Pre-2005 V6 Mustang 19 03-06-2009 05:18 AM
Couple valvetrain questions Ibanezplayer272 Pre-2005 V6 Mustang 25 09-14-2008 06:11 PM
Couple questions for ya Sassa Massa 1979-1995 Mustang GT 4 08-15-2006 06:20 PM
Couple of tire questions cterie Mustang Wheels & Tires 11 03-08-2006 09:35 AM
A couple of questions to kick around mohrnormal The Bar 3 02-09-2005 09:06 PM
06:03 AM
