I was in stop and go traffic and I noticed the temp gauge is above normal so I started watching it. At the next light I lose ac and she starts to buck and idle rough. Needle is just about to the H mark. I pull over and pop the hood while it is still running and I see the fan is not running. I let is set for about an hour. Came back and started it and the fan is running. Drove home on the interstate with no issues. Ordered and installed a new fan. Overheats in traffic. Ordered and installed a new thermostat. Overheats in traffic. Today getting a new high speed fan relay. If that doesn't work what else do I have. Please help.
Troubleshooting by throwing parts at it will only result in frustration and an empty wallet. Have you flushed the radiator? What year? What engine? How many miles? Any mods?
Yes. Overheated again after putting in a new high speed relay. I opened the hood and the fan was not running! That's what made me think it was the relay. Running out of options.
You should be able to remove the radiator cap and run the car until it reaches operating temp. You will see the coolant flowing as the thermostat opens?
Speaking of the thermostat, are you sure it was not installed upside down / backwards?
Coolant is circulating. So I took another look at the fan behavior. I start up from sitting all night and turn on the AC. Fan starts right up. I let it idle to temperature. Then I cranked the AC to max to get it to over heat. After a few minutes the temp starts to rise. The rpms change as the AC shuts down. After a few more minutes the fan shuts down and the temp starts to rise quickly.
Took it to the local mechanic for a computer diagnostic. Seems the new fan is faulty since the computer shows no faults or broken circuits. Fan is under warrantee and on its way back. New fan is on the way. More later
Problem persists 3 fans later! This time I installed the fan and did not turn on the AC to let the vehicle reach temperature naturally. Fan did not come on until nearing 12 o'clock. Held for good amount of time so I loaded the engine by starting up the AC. Held for a minute but soon started to rise and the fan shut off. That was it! Fan never started back up and the needle continued to rise. I don't own a tuner so my next stop is finding a local speed shop for help. BTW I connected my obd2 reader and it showed no codes.
Damn it, I know I replied with the solution, but, apparently that didn't last long as the overheating is back and the the fan won't turn on!! Did you ever figure the problem out?
I'm having the same issue!! Fan works fine, drive for a while but then stops working and overheat. Then the coolant starts to rise in the reservoir as if it has no where to go! Im about to change the coolant and thermostat as well as the temperature sensor. But I've read many sites about people having this issue and NO ONE has found out why and the problem still persists.
Figured out my problem. I have an SCT Tunner, and I messed with the radiator fan temp settings, I returned the car to Stock, programmed what needed to be changed back except for the fan temps. Overheat issue gone.
---------- Post added at 10:40 AM ---------- Previous post was at 10:40 AM ----------
Update.
Guys, I know it's a dead issue being beat here, but has anyone figured out the problem? It's going on two years and I can't figure the problem out. I'm seriously thinking about installing a separate switch to turn the fan on. Anybody ever do a manual turn on switch?
I had that same problem in my subaru b9 tribeca this week, I changed everything, hoses, radiator cleaning ,thermostat,coolant .....and kept going up. An the end, I looked the radiator cap and I saw that It had one of the ring cracks. I changed it for another and solved!!!!.
I was already thinking about changing the head gaskets
...sure sounds like a relay or temp sensor... swap all the matching relays around with matching ones in the relay box. The cost is zero. Start with the easy stuff. Has to an electrical issue..?
Yes. Check all of the fuses, relays, wiring, connectors, associated with the cooling fan circuit.
The Body Control Module is what ultimately controls the on/off/speed functions of the fan.
Are you try to change the temperature sensor?: is this sensor who says to the fan start,...through the ECU
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
