Can anybody possibly help me out with whether the adjustments that are available for this wing actually make that much of a difference on the street compared to the track?
I'd like to get as much down Force as possible seems like the tires break loose on this thing when I sneeze, and it has 345's on the rear. They are Nitto Invo's, not sure if that makes a big difference I know nothing about tires.
oltwings, not knowing the adjustability of the wing and what one position does over the other I was looking for any insight on it in general, But to answer your question, I would rather have it adjusted to give me any low speed grip help, at the moment this is just for driving on the back Country Roads don't know what speed the wing even helps at but I don't find myself going over 100 hardly for very long and was more interested if it has the capacity to help on Corners at 70 or 80 on average. If the wing only is beneficial at speeds over 100 the conversations a mute point.
I will be going to Lime Rock Park in Lakeville Connecticut in April for a track day I don't know what advice you would say about that but if you have any much appreciated.
Also, I guess if anything I just wanted to make sure I wasn't lifting the rear end compared to pushing it down.
Do you have lower control arm relocation brackets? Lowering the car and not relocating the control arm mounting point will pull weight OFF the axle when you get on the gas. That could be a big part of your wheel spin problem.
The car has many upgrades which I'm slowly figuring out, the guy I bought it from knew nothing about the cars past history.
Has Steeda lower control arms and a Steeda Watts Link System.
And someone who saw these pictures said the rear axle tubes are not stock, any comment on those?
The axle tubes appear stock to me, it seems they just cleaned it up and actually welded the Watts link in place. If the axle tubes are in fact stock, then it appears you do NOT have lower control arm relocation brackets. That is your problem, a lowered vehicle with no relocation brackets pulls weight off the rear axle on acceleration.
There are many good brands, but personally i like the BMR. Do some reading on lower control arm relocation brackets and pick the set you feel works best for you. Shouldnt be more than like $150 and an afternoon of wrenching.
Assuming my perspective is off, an easy way to check if you do need relocation brackets is to check the orientation of the lower control arms. At ride height, on level ground, they should either be parallel with the ground or have a slight incline downward towards the rear of the car. If the front of the control arm (mounted on the body) is lower than the rear mounting point (on the axle) then you need brackets.
Wow! Yes the front of my control arms are much lower than the rear.
How does it get that way? Was the car lowered that much that it reversed the angle?
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
