Raising Adjustable Suspension? - Mustang Evolution
Old 10-25-2017, 10:47 AM   #1
Roush adjustable suspension on 2008 Trak Pak.
The car sits quite low from what I see here of the threads (in pic) I can raise it up a half inch to an inch at max it seems,
Besides dealing with a stiffer ride which I don't know how bad that is until I try it.
I'm hoping this isn't a problem, I'm guessing that if Roush put that amount of variation in adjustability that it's okay to raise them up towards the top??
Someone mentioned to me that it's possible that would completely change my wheel alignment and if I do it I should get an alignment done is that true?
Any other advice much appreciated. Sorry, don't know why picture turns sideways while uploading!
ralfano is offline   Reply With Quote
Old 10-25-2017, 04:03 PM   #2
Revvv's Avatar
You will be fine dialing in your coil overs. Once you get everything where you want it, having the alignment checked would not hurt anything. You will likely be close to spec.
Old 10-25-2017, 05:46 PM   #3
Voltwings's Avatar
If you have coilovers get an actual corner balance. Take it to a shop that can do corner balancing and they will adjust the coilovers so that the diagonal split is as close to 50/50 as possible.
Everyone talks about a front / rear split, but what about left and right? Tuning for a diagonal split will attempt to make the car handle evenly in braking, accelerating, as well as turning in either direction.
kit for electronic adjustable suspension? MrFudgems 2011-2014 V6 Mustang 5 02-24-2016 12:17 AM
For Sale: UMI Performance Adjustable Lower Control Arms and Adjustable Panhard Bar BadCon Mustang Parts for Sale and Wanted 8 04-10-2015 01:58 AM
SR rear control arms Adjustable & Non-Adjustable mooseruler Mustang DIY and Technical 10 12-17-2014 09:27 PM
Adjustable Suspension Components? Frozen Yettie General Mustang Discussion 3 06-02-2014 02:18 PM
Adjustable suspension parts BigBlue5.0 2011-2014 Mustang GT 23 05-10-2014 08:17 PM
01:19 AM
