Fluctuating cold start up - Mustang Evolution
Old 11-13-2017, 08:07 PM   #1
truecarlos's Avatar
When I turn my 2005 mustang gt on in the morning or whenever,the rpm shoots to 2000rpm like normal but then when it tries to idle lower like it should, it moves back up to 2k(or higher if its cold in the morning). but after that it finally goes down to normal idle rpms. This started happening when shorty after I cleaned my air filter on my JLT cai. I think I might have re-oiled the filter too much but idk. any ideas? heres a link to the video https://youtu.be/pNcCQ4r7lmQ
truecarlos is offline   Reply With Quote
Old 11-14-2017, 07:15 AM   #2
Voltwings's Avatar
Probably did over oil it, it really should only be like a misting of oil when you re do it, it should barely be damp.
Just go to an auto parts store, get a can of MAF cleaner, take the MAF out and spray it down, and you should be ok.
Old 11-15-2017, 10:22 AM   #3
If doing what Voltwings suggested does not work, it may just take time for your computer to recalibrate the difference between a clean and a dirty air filter. So, doing nothing could be the solution.
KevinP is offline   Reply With Quote
Old 11-20-2017, 12:21 PM   #4
truecarlos's Avatar
Update: It still does the same thing even after I cleaned the MAF and waited it out
Cold start el_jefe5.0 2015 Mustang GT 2 10-25-2017 04:27 PM
Cold start TrevorMCA 2011-2014 V6 Mustang 9 12-10-2016 08:29 AM
Running lean on Cold start in cold temperatures. Zed 2011-2014 Mustang GT 3 09-24-2014 08:23 AM
Cold Start?? FrvrDreamin 1996-2004 Mustang GT 15 11-07-2006 10:17 AM
08:32 PM
