I just bought a 2005 GT two weeks ago. The car has 61500 miles on it. When I first drove the car with the previous owner, he told me to go very easy until it warmed up, as apparently there was an intermittent issue of it not running properly until warmed up. In the two weeks I've had the car, the only thing I noticed was one time upon start, there was a little smoke from the exhaust. Otherwise, it started and ran just fine. The only mod to this car is a cold air intake and Ford Racing exhaust.
I had the oil changed and a general 60k mile inspection done at the dealer last week and everything checked out normal.
Today I went to start it and it fired up, partially, then died. I restarted and it barely fired up and died again, emitting big puffs of smoke from the exhaust. Several more attempts yielded the same thing and it just would not fire up. Also smelled like it might have been getting too much fuel. I let it sit for 5 minutes and tried again with final success, although before it started firing on all cylinders I thought it would stall again.
It now appears to be running ok but I'm not sure this won't happen again. My only recourse is to probably take it to the dealer and have it checked out.
Any insights or suggestions? Thanks much.
Warren
Warren
