Help stock airbox - Mustang Evolution
Old 12-23-2017, 05:40 PM   #1
truecarlos's Avatar
Help stock airbox
I got a new stock air tube and airbox for my 2005 mustang gt. After I installed it, the car would try to start but then fails? Why?
truecarlos is offline   Reply With Quote
Old 12-23-2017, 06:25 PM   #2
Did you plug everything in? Did you re-use the same MAF? Did you make sure all vac hoses are hooked up? Sounds like an install error tbth.
Old 12-23-2017, 07:11 PM   #3
jkeaton's Avatar
Go back and check your work.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 12-23-2017, 07:18 PM   #4
truecarlos's Avatar
I did plug everything correctly, but I do have the pcv hose from this old jlt cai and not the stock hose, i wonder if that could be it
Old 12-23-2017, 09:29 PM   #5
As long as there are no vacuum leaks, the PCV hose is probably fine.
Did you remove the MAF sensor from the JLT and install it into the stock air box?
And have you tried unplugging the MAF sensor, and then try to start the engine?
Old 01-02-2018, 11:39 AM   #6
I don't think that the tune would be that different for a simple CAI, but any chance that there is a different tune on the car that is incompatible with the new setup?
KevinP is offline   Reply With Quote
Stock airbox 5LHO 2011-2014 Mustang GT 15 08-18-2017 04:55 PM
For Sale: 2011-2014 GT Stock Airbox w/ Filter Fax22 Mustang Parts for Sale and Wanted 1 08-13-2017 04:51 PM
Wanted: 2003 Mustang airbox grommets rosad Mustang Parts for Sale and Wanted 0 02-26-2015 12:51 PM
Stock Airbox Mkolabin 2005-2010 V6 Mustang 8 02-22-2013 11:57 PM
01:19 AM
