Dyno results - Mustang Evolution
Old 10-04-2008, 02:55 PM   #1
gmantheman's Avatar
Dyno results
Here are some dyno numbers before and after Bama Tunes and JLT. The first set of numbers I had an 87 canned tune. On the dyno pull with the intake/tune. I was using 91 octane. First run is with 87 per. tune, second run is 91 race tune, third and fourth is 91 tq tune. The race and tq tune are close through out the entire RPM range. My mods are JLT intake, Bamachip tunes, Steeda UDP, and magnapacks. I also have 4.10s, but they don't affect dyno numbers.
Name:	Dyno pull  87 canned tune.jpg
ID:	19733   Click image for larger version
Name:	Dyno after Bama and JLT.jpg
gmantheman is offline   Reply With Quote
Old 10-04-2008, 03:28 PM   #2
1234's Avatar
Re: Dyno results
Thats not bad at all for the mods you have.
Old 10-04-2008, 04:22 PM   #3
Herbstang's Avatar
Re: Dyno results
Nice Numbers
Old 10-04-2008, 04:23 PM   #4
gmantheman's Avatar
Re: Dyno results
There doesn't seem to be too much difference in tq between the canned 87 tune and Doug's 91 tunes. 8LBS is not that much. I guess I was expecting a bigger difference.
Old 10-04-2008, 04:24 PM   #5
Herbstang's Avatar
Re: Dyno results
We always hope for more
Old 10-05-2008, 05:14 PM   #6
Re: Dyno results
Still say that you should go see Adam, but you do have some good numbers. Worried about you A/F readings.
msgt46270 is offline   Reply With Quote
Old 10-05-2008, 05:29 PM   #7
gmantheman's Avatar
Re: Dyno results
I am thinking about going to Adam, but I am thinking I need to hold of on per. mods and get ready to replace wear and tear items such as break pads.
I emailed Doug in regards to my A/F. I hope he can send me new tunes.
Old 10-06-2008, 08:36 AM   #8
Re: Dyno results
your a/f is off but doug is pretty good, he is local to me and everyone around here gets good results on their 05+ cars. Give him a call first and fax him those sheets and see what he will do.
Old 10-06-2008, 12:32 PM   #9
gmantheman's Avatar
Re: Dyno results
I emailed Doug this weekend and I attached the dyno sheet, and he already replied. He said my A/F is within 1-2% of 13.0, which is good. The only pull were the A/F was off was the 1st pull, which is the blue graph on the bottom. But for that pull I used the 87 octane tune, but I was using 91 octance gas, so that may be the reason for the rich A/F
Old 10-06-2008, 03:42 PM   #10
Re: Dyno results
wow i assumed 13.0 was pretty darn lean interesting
Old 10-06-2008, 03:47 PM   #11
Re: Dyno results
13.0 is very lean for a blown car...N/A your target is around 13.0-13.2ish I beleive....with 13.0 being kind of the optimum location. Stoich is 14.7, so, in reality, 13.0 is kinda rich N/A theoretically
Old 10-07-2008, 01:23 PM   #12
Re: Dyno results
good to know
dyno results are in (2.93 pulley) SpectorV 1996-2004 Mustang GT 10 01-19-2010 10:55 AM
Dyno results after bolt-ons - 07 GT 07GT 2005-2010 Mustang GT 16 04-09-2007 07:19 AM
SCT Tune / Dyno #2 Results 2005RedGT 1996-2004 Mustang GT 9 02-21-2005 10:36 AM
Air Silencer Dyno results ? drichard Pre-2005 V6 Mustang 4 10-15-2003 06:10 PM
08:51 PM
