Car Problem, What do you guys think? - Mustang Evolution
Old 11-23-2008, 11:55 AM   #1
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
So, my rpm gauge isn't reading and my interior lights are dim ... i thought maybe alternator but my volt gauge reads okay (credit to lowflyn) and ... i'm stumed. ideas?
05 Stang to the Bang! X-Pipe, Headers, Stage 2 Roush Kit, Tuner, JBA Exhaust and about a million and 4 Horsepower.
braumab is offline   Reply With Quote
Old 11-24-2008, 10:06 AM   #2
Herbstang's Avatar
Re: Car Problem, What do you guys think?
Found this
Tachometers
The tachometer is a sensitive instrument that functions based on input from the engine’s ignition system. The tachometer gets its power from the ignition switch (ignition on) and its input from the negative (distributor) side of the ignition coil. Tachometers are rarely serviceable because they tend to be factory sealed. Absence of function is most often caused by a disrupted connection between the ignition switch and the tachometer or between the ignition coil and tachometer.
Check your voltage limiter behind the instrument panel.
Old 11-24-2008, 10:26 AM   #3
braumab's Avatar
Region: Arkansas
You think the voltage limiter may have gone bad? i've noticed it's all interior lights are dim. the radio lights, instrument panel lights, etc.
Old 11-25-2008, 09:42 PM   #4
Man...if this ends up being a wiring issue you're in for a long haul. Bring the car and some beer and we'll start tracking lol.
At this point your best bet will be to just start troubleshooting.
Old 11-28-2008, 04:11 PM   #5
MonteCitan's Avatar
I just had this same sort of issue with the 92..
The lights were dim, my instrument cluster was effed up (tach was jumpy, voltage gauge read way low an temp gauge shot way up) and my turn signals wouldn't ... click... - they'd come on and just hang
Ended up being one of the grounds that runs from the battery to the fenderwell - once that was fixed the car ran perfect and the gauges work better and smoother than they have since I got the car 3 years ago..
- Couldn't hurt to start by checking the battery cables and basic grounds - if your alternator was charging poorly, your low voltage light would come on
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-01-2008, 10:18 AM   #6
braumab's Avatar
Region: Arkansas
yeah, i've also noticed this over the weekend.... It's cold, and i like to let my car running for 10 minutes before I get in. After it sits for 10 minutes and warms up, the problem is non existant. If i just crank it and go, then i have the issue. Does this sound odd to anyone?
Old 12-01-2008, 11:22 AM   #7
Do you still have your warrenty?My 1st stop would be the dealer with that type of problem, expically on a newer car.
05GT BBK headers,BBK 62 mm TB , off rd x pipe , magnaflow exhaust , Vortech HO kit , corba injectors , corba fuel pumps , upgraded pullys , Lightspeed Inovations custom tune 445hp and 400ft/t to the ground
sporter is offline   Reply With Quote
Old 12-01-2008, 12:06 PM   #8
braumab's Avatar
Region: Arkansas
not sure? I bought it from a used dealership, i'm pretty sure the warranty is probably void by now though.
Old 12-03-2008, 03:00 PM   #9
The Darkside's Avatar
i think you should atleast try to talk to the dealer bro. See what they say.
your problem is beyond my knowledge. sorry i cant help more.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 12-04-2008, 07:42 AM   #10
braumab's Avatar
Region: Arkansas
any ford dealer?
Old 12-04-2008, 10:39 AM   #11
Originally Posted by braumab View Post
any ford dealer?
you should go to the dealer you bought it from. they are usally the ones that hold the warrenty. if its a second hand car then ask the guy you bought it from where he or she bought it from.
i bleed Race fuel!
Old 12-04-2008, 01:07 PM   #12
braumab's Avatar
Region: Arkansas
oh, awesome. thanks.
Big Problem Guys- Engine shuts down! DMAC Pre-2005 V6 Mustang 7 12-03-2007 10:29 AM
Car Cutting off Problem SC_STEEDA Pre-2005 V6 Mustang 4 10-26-2007 12:44 PM
Car problems continue,Speedo' problem Dark02Pony Pre-2005 V6 Mustang 4 09-22-2005 12:19 PM
Car wash problem.... douGT The Bar 15 03-28-2005 12:27 PM
here's a problem for you mechanically inclined guys jimmy_beaner 1996-2004 Mustang GT 16 09-12-2004 12:31 PM
10:54 AM
