Stock block and supercharger pully ??? - Mustang Evolution
Old 11-28-2008, 06:20 PM   #1
He guys , I was just woundering what the limits of my 3v are.Currentlly the car makes 445hp and 400ft/t to the ground,i am not sure about flywheel HP but i would guess around 490-500hp?My question is how much more power will it safely handle?I still plan on heads , cam and a methonal kit , plus i want to run a little more boost.
my other ??? is do you know the size of the stock pully on the HO kit?and to increase boost you would go smaller cause it will spin faster???
thanks again
05GT BBK headers,BBK 62 mm TB , off rd x pipe , magnaflow exhaust , Vortech HO kit , corba injectors , corba fuel pumps , upgraded pullys , Lightspeed Inovations custom tune 445hp and 400ft/t to the ground
sporter is offline   Reply With Quote
Old 12-03-2008, 03:16 PM   #2
The Darkside's Avatar
Re: Stock block and supercharger pully ???
thanks again
Those are some DAM impresive numbers man! your probebly maken about 500 hrs. from what i heard if you go forward from this point on youll have to get ported heads, new rockers, ect. ect. its basically time to make your engine strong enough to hold all the new pressure you want to put on it.
although, im not positive, but i think you could safely go to stage 2 cams from comp cams and not worry about it. you should gain another 25 hrs from that.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 12-04-2008, 10:06 AM   #3
You are at the limits of a stock block. I wouldnt push it any harder if you want to keep the motor alive for awhile. I would do a built bottom end before i did the built top end.
Benjytps is offline   Reply With Quote
Old 12-04-2008, 10:33 AM   #4
You can get further than you are now, but like Benjy said, you are at the safe limits now. Locally, a shop was able to run 515 rwhp/tq out of their 05 GT on stock bottom end with a saleen SC @ 15psi I believe. The car ran strong and never blew up. They were trying to blow it up and see how much it would take, but it would not blow. The reason I'm sure was in the tune. The car spent a lot of time getting the tune very dialed in.
Today, the motor is dead finally....3 years after they cranked up the boost.
Like Benjy said, I would definitely build your bottom end before you go any higher. Or, go higher, but it will be a crap shoot as to whether your car survives. One bad tank of gas and it will pop.
Old 12-04-2008, 01:04 PM   #5
thats what i thought,well i guess its time to do a bulid,what combo do you guys like?
thanks again
Old 12-05-2008, 12:54 PM   #6
thanks again
im the wrong person to really awnser this question but i will tell you what i have heard. ive heard c n c ported head, manely rods. thats all i remember. and they do have a bigger intake manifold avalible in aluminum now as well.
im sure venom can tell you more.
i bleed Race fuel!
supercharger for stock 4.6... just curious redbird2289 1996-2004 Mustang GT 11 08-23-2009 02:57 AM
03/04 Stock Eaton Supercharger slostang Mustang Parts for Sale and Wanted 7 10-12-2007 06:43 PM
FS: Stock 03 Cobra Eaton Supercharger, TB, Plenum - $500 shipped PureVenom Mustang Parts for Sale and Wanted 18 02-07-2007 12:32 PM
How stout is the stock block? PureVenom Pre-2005 V6 Mustang 46 02-27-2006 03:21 PM
supercharger on stock v6 bigpomps Pre-2005 V6 Mustang 17 11-12-2004 09:21 AM
11:40 PM
