NEED HELP NOW!!!! - Mustang Evolution
Old 11-30-2008, 08:05 PM   #1
JamesCB57's Avatar
NEED HELP NOW!!!!
OK so hi i'm James and last friday i bought a 05 GT 5M with 34k miles. It ran perfectly until i decided to tinker with it. I put on a cat-less X-pipe, and changed the oil to 10w-30 royal purple. After a day or so driving around without cats i put them back on but left the X-pipe. Now I have an awful knock. Could it be the oil, or did i screw up the timing running cat-less???
JamesCB57 is offline   Reply With Quote
Old 11-30-2008, 08:35 PM   #2
Re: NEED HELP NOW!!!!
Could you be a little more descriptive on the knock? Can you pinpoint where it's coming from, when it's happening, etc...
Old 11-30-2008, 08:37 PM   #3
JamesCB57's Avatar
It is coming from the heads, it barely does it at idle, but it progressively gets louder as i go to about 3k RPMs. At that point its awful i feel like im punishing it
Old 11-30-2008, 08:42 PM   #4
Have you checked the oil level since doing the oil change?
Old 11-30-2008, 08:57 PM   #5
JamesCB57's Avatar
yea an its fine
Old 11-30-2008, 09:17 PM   #6
Is the car throwing a check engine light?
Old 11-30-2008, 09:31 PM   #7
JamesCB57's Avatar
it did but then it turned off
Old 11-30-2008, 09:40 PM   #8
Thomas91169's Avatar
exhaust leak at the header to midpipe connection.
unless your motor decided to randomly spin a bearing.
-Thomas-
Old 12-01-2008, 09:19 PM   #9
JamesCB57's Avatar
I was kind of thinking that was it after crawling under it today.....I retightened all bolts and put muffler-weld around the connections we will see how that works out for me tommorow
Old 12-01-2008, 10:25 PM   #10
how about the VCT system,its a weak point in the 3v.Livornoris motorsports has a little writeup on it
05GT BBK headers,BBK 62 mm TB , off rd x pipe , magnaflow exhaust , Vortech HO kit , corba injectors , corba fuel pumps , upgraded pullys , Lightspeed Inovations custom tune 445hp and 400ft/t to the ground
sporter is offline   Reply With Quote
Old 12-02-2008, 07:09 PM   #11
JamesCB57's Avatar
Victory is mine......I had completely lost a header nut...went to ace bought some replacements and some high heat loctite and she runs like a beauty now
Old 12-03-2008, 01:45 AM   #12
w00t i win with exhaust leak! was wrong about placement though. Cookie?
-Thomas-
Old 12-03-2008, 02:58 PM   #13
The Darkside's Avatar
2 chocolate chips cookies for the man!
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 12-04-2008, 01:13 PM   #14
i would post u 1 but i dont know how
Old 12-05-2008, 12:41 PM   #15
why did you put the cats back on in the first place. you should have just gotton a tuner and taken off the rear banks of the o2 sensors. Any luck on the knocking?
i bleed Race fuel!
11:56 PM
