O2 SENSOR - Mustang Evolution
Old 01-12-2009, 01:46 PM   #1
O2 SENSOR
Hey guys im having some issues with my 02 sensors. it started about a while ago after intalling my long tube headers. I had the tune already installed not long after i got the mil that the bank 2 sensor 1 was slow to respond. after that i replaced it and then i started runnin lean cuz of the other 02 sensor so i replaced the other, and im gettin the mil light again that the sensor is slow to respond. What can i do to fix this? Thanx
redGT773 is offline   Reply With Quote
Old 01-12-2009, 02:59 PM   #2
Re: O2 SENSOR
with long tubes you will be tripping a light as you wont have cats any more (or do you have them?) if you dont you will need to turn off the CEL you get from no cats being seen.
Old 01-12-2009, 03:07 PM   #3
Re: O2 SENSOR
whats the CEL and no i don't have cats
Old 01-12-2009, 06:23 PM   #4
hottcobra's Avatar
Re: O2 SENSOR
CEL=check engine light.
what brand headers do you have?
and did you chack for any exhaust leaks?
Old 01-12-2009, 08:37 PM   #5
Re: O2 SENSOR
bbk long tube headers, to off road xpipe to flowmastermufflers. yup no leaks
and this is the code i keep getting P0133
Old 01-13-2009, 01:27 PM   #6
Scut95's Avatar
Re: O2 SENSOR
OBD-II Trouble Code: P0133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1) Check out this page. It tells you what it is and some possible solutions to the problem.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 01-13-2009, 03:16 PM   #7
The Darkside's Avatar
Re: O2 SENSOR
ok this is weird, me and you sound in similar situations. i have headers no cat, supercharged v6 and i got the same code you got, however i was told that my car needs a new stronger fuel pump because im making close to 400 hrs and the stock pump might not be able to handle that. I say try replacing the o2 sensor first.
also im gussing when you got it tunned you have bank 2 turned off since you dont have cats. im giong to get that pump installed in 2 weeks, lets see what happens.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 01-13-2009, 05:59 PM   #8
Re: O2 SENSOR
I have already replaced both sensors, i have also looked up the trouble code so dunno only thing i can think of now is something wrong with the tune.
Old 01-13-2009, 09:45 PM   #9
Re: O2 SENSOR
so your still geting the code?? did you do anything else to the car? supercharged?
make sure that bank 2 on the o2 sensors are off. let me know bro.
i bleed Race fuel!
Old 01-14-2009, 05:19 PM   #10
Scut95's Avatar
Re: O2 SENSOR
Technically it's not called bank 2. The O2 sensor or sensors are called the after cat sensors. Bank 1 means that the sensor measures the engine side with cylinder 1 and bank 2 means it measures the cylinders not containing cylinder #1. There are pre and post cat sensors and the post just measure to see if the cats are working. The pre-cat sensors actually measure the engine's performance. I just wanted you to have the proper terms.
95 GT- Sold
Old 01-15-2009, 01:43 PM   #11
Re: O2 SENSOR
yep exactally what i ment, except you explained it a million times better lol yah so i hope he has the post cat sensor turned off. im curious since i was getting the same issues. But the thing that gave it away for me that it was my fuel pump was the following.........tell me what you think.......car is making close to 400 at the crank. now my alternator had actually kicked the bucket and i didnt know, my car was running on the battery. so i cant running lean because at exactally 12 volts my fuel pump just barely makes enough to support the horses. so i got the alternator changed. 3 days later i went to an resturant with valle parking and i noticed that he left my hazzard lights on for about a hour! and my car was off so it was using battery. after i left i got the running lean code again. so what my mechanic thinks is that the battery was low and thats why it wasnt getting enough fuel.
i have ordered the gt500 fuel pump to be installed at the same time as the gears, along with a GOOD air fuel gauge to make sure the cars running right.
what you think???
i bleed Race fuel!
Old 01-16-2009, 08:30 PM   #12
hottcobra's Avatar
Re: O2 SENSOR
the battery that comes with the car is crap. I would go ahead and swap it for an optmia
Old 01-16-2009, 09:00 PM   #13
jimmy_beaner's Avatar
Region: Iowa
Re: O2 SENSOR
I keep getting p1131 and p1151... still working on figuring out WHY though.
Old 01-16-2009, 09:44 PM   #14
Re: O2 SENSOR
It's got to be your leaks by the sensors like we talked about earlier.
Old 01-16-2009, 09:47 PM   #15
hottcobra's Avatar
Re: O2 SENSOR
If you have any leaks before the sensor, it's gonna throw codes
Old 01-16-2009, 09:48 PM   #16
Region: Iowa
Re: O2 SENSOR
yeah... now if that epoxy did ANYTHING.... I need to knock that strap off and really get it on there
Old 01-17-2009, 11:47 AM   #17
Re: O2 SENSOR
No ****, it's too damn cold for it. I told you you will have to wait till it warms up to apply it....
Old 01-17-2009, 11:49 AM   #18
Region: Iowa
Re: O2 SENSOR
I had the exhaust tubes very hot I figured that might work
Old 01-17-2009, 01:07 PM   #19
Re: O2 SENSOR
Um, yeah, no. It's air temp not surface temp that affects curing time.
Old 01-17-2009, 01:29 PM   #20
Region: Iowa
Re: O2 SENSOR
yeah, it said it would set up in temps down to -90. It was cold, but not quite that cold I suppose I will wait. It is 24 today... by tomorrow it should be 68 degrees if this current heat wave continues
Old 01-18-2009, 02:02 PM   #21
Re: O2 SENSOR
yah ill probebly do that when i get everything done.
i bleed Race fuel!
Old 01-29-2009, 01:17 PM   #22
Re: O2 SENSOR
so is that car still thowing that code? did you solve the problem?
i bleed Race fuel!
o2 Sensor problem 19Delta Pre-2005 V6 Mustang 4 07-17-2009 01:51 PM
M.A.F. Sensor 03GTNEWB 1996-2004 Mustang GT 5 07-15-2008 11:45 AM
MAF Sensor?? Rocket50 1979-1995 Mustang GT 2 12-23-2006 09:36 AM
o2 sensor Mustang414 Pre-2005 V6 Mustang 0 05-18-2005 08:36 PM
O2 Sensor Out. Dom Pre-2005 V6 Mustang 18 12-18-2004 07:58 PM
05:48 PM
