overdrive - Mustang Evolution
Old 01-30-2009, 01:10 PM   #1
The Darkside's Avatar
overdrive
Hey heres a question that im sure alot of you like venom, brent, dadant, 1234, hotcobra can awnser.
my car has an overdrive button as we all know. i feel what it does, i see that the car drives in a higher rpm range and the torque convertor seems to generate less stall when its off but could somone explain to me how exactally the overdrive works.
what are the mechanics of it. i like learning this stuff and you guys are like my yoda/obi wan lol
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 01-30-2009, 01:27 PM   #2
hottcobra's Avatar
Re: overdrive
Well without going into all the working of an auto trans. your car has a 5 speed atuo trans. each gear ratio has it's own clutch pack as it shirts gears the diff. clutch packs ingauge turning the sun gear and planitary gears diff. ways which gives your your diff. gear ratios. 1ft through 3rd gear are underdrive gears 4th is your 1to 1 gear and 5th is your overdrive. 1 to 1 gear is for ever single complete turn of the trans. input shaft the output shaft makes one complete turn. overdrive is when the output shaft makes a complete turn before the input shaft. so when you turn off the overdrive button the the trans. downshifts from 5th to 4th.
Old 01-30-2009, 01:29 PM   #3
Re: overdrive
Your overdrive button is actually an over ride button. What it does is it prevents the transmission from going into overdrive when you push it. Basically, it takes your 5 speed transmission and locks it out of 5th gear which is your over drive gear.
Your overdrive is solely for cruising to cause the least amount of work for your engine. As such, when you are racing, or trying to pass, or trying to pull something....you don't want your car to be low in the RPM range, you want it higher up where you are making more power.
I see Louis has replied already, so I'll stop here...let me know if between mine and his you still have questions.
Old 01-30-2009, 01:35 PM   #4
Re: overdrive
ok here is what my dumbass is understanding, basically the 1st and 5th gear are effected by the overdrive being on. and when its off the car downshifts from 5th to 4th? thats why the rpms are so high?
i bleed Race fuel!
Old 01-30-2009, 01:38 PM   #5
Re: overdrive
ahhhhhhh ok, thats coupled with hotcobras awsner helps me alot. locks out the 5th gear, that makes sence.
thank you guys both, another thing learned!
i bleed Race fuel!
Old 01-30-2009, 01:38 PM   #6
Re: overdrive
RPM's rise because you are no longer in 5th gear. 1st gear isn't affected by over drive at all.
Basically, 5th gear is a less than 1:1 ratio. This means that for every 1 turn of the transmission, your drive shaft is turning less than 1 full rotation. Therefore, your RPMs stay lower.
When you turn overdrive off by pressing the button, It's jumps from this say .7 ratio gear to a 1.0 ratio gear. Therefore your RPMs jump immediately because your trans is now spinning your drive shaft faster which in turn is spinning your wheels faster.
Old 01-30-2009, 01:44 PM   #7
hottcobra's Avatar
Re: overdrive
FYI dyno your car in drive with the overdrive button off. I've seen shops dyno S197 cars with it in 3rd and wonder why the #s are off
Old 01-30-2009, 01:46 PM   #8
Re: overdrive
you know.......i wonder if when they dynoed it they did that......ill have to ask.
i bleed Race fuel!
Old 01-30-2009, 01:47 PM   #9
Re: overdrive
Wow.,...that's just silly. They should have just locked it in forth like they do with the 99+'s with locking them in 3rd.
Old 01-30-2009, 01:48 PM   #10
Re: overdrive
Did your numbers seem really high? If so, then it could have been in 3rd. If they seemed super low, then it could have been in 5th if they weren't pressing the gas real hard.
Old 01-30-2009, 01:49 PM   #11
hottcobra's Avatar
Re: overdrive
you would think the #s would be high but they actually are lower. I know cause the first pull I made with my car I did this.
Old 01-30-2009, 01:50 PM   #12
Re: overdrive
ok see now i have a question about this, if it doesnt really affect anything except 5th gear why is it that the car responds so much quicker with the overdrive off, its like haveing a diff car, even from 1st -3rd. or is it just my imagination??? it drives like a diff car......i know that my supercharger give out more power at higher rpms so i understand that part too.
just an example, today on the way to my speed shop i met a camaro on the road, nicely done. ofcourse we both got sucked into a race. i was ahead of him but not by alot, the next turn after we slowed to 15mph, i turned the overdrive off and put my foot down......i flew away!! litterally i was just gone. why is that?
i bleed Race fuel!
Old 01-30-2009, 01:50 PM   #13
Re: overdrive
Hmm....that seems off....but could be right. I mean, I think I've seen manuals dyno in 3rd gear post some rediculously high numbers....I would think it would be for autos as well.
Old 01-30-2009, 01:52 PM   #14
Re: overdrive
the number seemed low. my speed shop owner was like confused a little bit. hes like i swear before this custom tune and before the long tube headers, no cats, x pipe you were putting down 320 rwhp and now your putting down about the same?? but we didnt question it too much. this time he didnt do the dyno himself, my mechanic next door who does the custom tuning did it, maybe he didnt know to turn off the over drive!
i bleed Race fuel!
Old 01-30-2009, 01:53 PM   #15
hottcobra's Avatar
Re: overdrive
your talking apples and oranges with sticks and atuos
Old 01-30-2009, 01:53 PM   #16
Re: overdrive
Typically, in the computer it will also hold out the RPMs between shifts longer...meaning instead of shifting into 3'rd gear at 4500 rpms, it'll wait till 5000. That's why it seems different. The shift points get tweaked because the car doesn't have as many gears anymore so the computer adjusts for it. It's kind of like a poor man's "performance mode".
Old 01-30-2009, 01:53 PM   #17
Re: overdrive
Yeah, I know...that's why I said it seems off but could be right as far as I know.
Old 01-30-2009, 01:53 PM   #18
hottcobra's Avatar
Re: overdrive
I would think it's in your head, but it may change the way the convertor goes into lockup but I dought it
Old 01-30-2009, 01:54 PM   #19
Re: overdrive
very intresting stuff. man i wish i could work on my car and learn this stuff.
i bleed Race fuel!
Old 01-30-2009, 01:55 PM   #20
hottcobra's Avatar
Re: overdrive
the power is low because the convertor won't go into full lockup in 3rd
Old 01-30-2009, 01:56 PM   #21
hottcobra's Avatar
Re: overdrive
it took 8 years of dealership training and working on car at the house with my dad since I was a child to get me here
Old 01-30-2009, 01:56 PM   #22
Re: overdrive
one of my boys said somthing about the converter too, so maybe that has somthing to do with it. i wish i lived near you guys, id just have you drive it and tell me what you think lol
i bleed Race fuel!
Old 01-30-2009, 01:58 PM   #23
Re: overdrive
yesss that makes sence i do see that, i do see it shift at higher rpms, i can hear it. if overdrive if off and i floor it, it shifts into 2nd like when its almost redlined.....that makes sence.
i bleed Race fuel!
Old 01-30-2009, 01:58 PM   #24
Re: overdrive
It's taken me a couple years of working on my own stuff without a clue doing things the wrong or hard way to learn the right way to do things....and a lot of pride swallowing questions to people asking for help/advice and a ton of reading online about different issues/mods/etc to get me here.
Old 01-30-2009, 02:02 PM   #25
hottcobra's Avatar
Re: overdrive
I guess I don't notice that cause my car does this with the tune I have in overdrive. The tune was the first thing I had so I didn't get much seat time stock. I know your car isn't stock but I don't know if you have any tuning done to the trans.
Old 01-30-2009, 02:04 PM   #26
Re: overdrive
your lucky....my dad is nothing like me.....he doesnt even like cars...or fighting for that matter and i fought on the circut for like 7 years. he never saw even one match. my teacher had to be the one to tell him in 97 that i was number 2 in the country. i envy you man......your lukcy.
i bleed Race fuel!
Old 01-30-2009, 02:05 PM   #27
Re: overdrive
well guys like you make it easy to ask. i dont feel bad asking because you dont make me feel like a dumbass lol i appreciate that. i guess your just passing down you knowledge.
i bleed Race fuel!
Old 01-30-2009, 02:06 PM   #28
Re: overdrive
i dought it man, i think my guys just sent the specs to the sniper comany and they sent back a tune and he just adjusted a few things. i would like it tuned nicely to the point where each gear shift is calibrated. but doesnt that usallly cost big bucks?
i bleed Race fuel!
Old 01-30-2009, 02:09 PM   #29
hottcobra's Avatar
Re: overdrive
I bought my tune from Brenspeed and it was the cost of the handheld only and they did everything. If you datalog your car and send it to brenspeed they can right a new tune for you for like $150. with everything. what handheld are you using?
Old 01-30-2009, 02:10 PM   #30
hottcobra's Avatar
Re: overdrive
I don't know why people don't pass on their knowlage to everyone. I will help anyone who wants it.
Old 01-30-2009, 02:13 PM   #31
Re: overdrive
Oh, well, you should hear what we say about you when we all get together have have a few beers.
Not really, I mean a custom dyno tune will only run about $400-500 and as part of that most tuners will also tune the transmission to maximize the power from the tune.
Old 01-30-2009, 02:15 PM   #32
Re: overdrive
He's using the Sniper.
Old 01-30-2009, 02:16 PM   #33
hottcobra's Avatar
Re: overdrive
[QUOTE=PureVenom;542929]Oh, well, you should hear what we say about you when we all get together have have a few beers.
na we only talk **** about jimmie_beaner and Thomas
Old 01-30-2009, 02:17 PM   #34
Re: overdrive
Well, everyone talks about thomas...not even just on this board...we even have it on video if we can find the video from the alabama get together a couple years ago.
Old 01-30-2009, 02:19 PM   #35
Re: overdrive
LMAO hahahahhah i can see it now. that ken is such a dumbass lol hahahahah ill have to deff look into that tune when i get more money. right now im breaken the bank somtime next week for the gears, a/f gauge/fuel pump and today i got a new battery. freaken 200 bucks. yah my wife is not happy lol
i bleed Race fuel!
Turning of Overdrive, does it go into “Performance Mode”? Renegade 800 Pre-2005 V6 Mustang 13 06-27-2008 05:58 PM
overdrive Mustang GT HO 1996-2004 Mustang GT 4 05-04-2008 11:19 PM
Using OVERDRIVE jaredp Pre-2005 V6 Mustang 16 01-27-2007 12:36 PM
Overdrive question didnt know where to put this 95 DrOpToP Pre-2005 V6 Mustang 4 02-08-2005 08:36 PM
Question about Overdrive light Twitch Pre-2005 V6 Mustang 6 02-11-2004 04:05 PM
10:05 AM
