Best shifter... Hurst? Steeda? - Mustang Evolution
Old 02-27-2009, 10:05 PM   #1
Thinking about this shifter...
Hurst Billet Short Throw Shifter Mustang GT (05-09)
Any experience with this shifter? Is installing this a doable weekend project with common tools and common mechanic ability?
RedFire2006 is offline   Reply With Quote
Old 02-27-2009, 10:21 PM   #2
Re: Best shifter... Hurst? Steeda?
IMO the MGW shifter is the best but if you want the handle sticking out of the shift boot hurst is about your only option. Its a good shifter just not what I would want.
If you have any idea how to work on a car you should be able to do the install pretty easy.
Old 02-28-2009, 12:49 AM   #3
bbunt302's Avatar
I like either the PRO 5.0 or the MGW. PRO 5.0 if you want something that feels extremely sturdy and makes it almost impossible to miss the 2-3 shift. MGW if you want something that's a little less notchy and has a slightly more "comfortable" feel.
I have a MGW now and miss my PRO 5.0.
Scary stuff.
Old 02-28-2009, 08:59 AM   #4
A shifter is a pretty straight forward install. It will probably take you longer to pop the plastic trim off the interior than it will to swap the shifter out.
Old 02-28-2009, 03:25 PM   #5
the 05+ may be harder or easier than the pre 05's ive never done a newer stang
Old 02-28-2009, 08:38 PM   #6
jimmy_beaner's Avatar
Region: Iowa
MGW is :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool: :drool:
Old 03-01-2009, 07:09 PM   #7
Y2E0L0L5OGWT's Avatar
Installing a shifter on the 05+'s is a very easy intall...it's 4 bolts that you have to remove...it will take about 45 minutes at the most...The 05+ GT shifter doesnt go directly into the transmission like previous generation shifter; it uses a long mechanical linkage assembly to do it, which is what tends to give the 05+'s a "herky-jerky" shifting feel...
I have a Roush Shifter in my Mustang...It has the shortest throw of any of the aftermarket shifter for the 05+'s...you can also get the long shifter handle like that one available for the Hurst Shifter...Really any of the top brands would give you a much stiffer feel with a shorter throw, including: Hurst, Roush, Pro 5.0, Steeda Tri-Ax, and MGW...
Old 03-11-2009, 06:55 PM   #8
Jerseyautoparts's Avatar
i have the hurst and i like it. the throw is much shorter. Install takes about an hour. Two max. Very easy and straight forward.
2007 Ford Mustang GT
Jerseyautoparts is offline   Reply With Quote
Old 04-01-2009, 04:27 PM   #9
GOStang08's Avatar
I have the Steeda Sport. I got it from a Mustang shop in DFW. I was going to go with the MGW but the guys there said that the Steeda Sport was the best on the market. I haven't had any problems and it took me and my bf just under an hour and I did all of the under-the-car work.
GOStang08 is offline   Reply With Quote
Old 04-09-2009, 12:37 PM   #10
The Darkside's Avatar
I have no idea about how short the throws are since i drive a automatic lol please no one boo me lol
but i love the look of the hurst!
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
Old 04-09-2009, 04:46 PM   #11
brian@afm's Avatar
We've installed the Hurst, Steeda, and Roush shifters for the 05-09, and, our customers seem to be the happiest with the Steeda.
Brian Koestner
Anderson Ford Motorsport
Ph 217-935-2076
Roush Power Pipe Cold Air Intake PMS and Camshafts
Dyno Tuning since 1995
"The Other Brian"
brian@afm is offline   Reply With Quote
Old 04-09-2009, 09:52 PM   #12
Cobra GT's Avatar
Is the Steeda all its cracked up to be?
1996 GT (sold)
1997 Cobra
1993 Ranger GT (not broke)
Want an 03/04 Cobra
Born:5/23/97, Build # 5722 of 6961 Builds
Cobra GT is offline   Reply With Quote
Old 04-10-2009, 10:49 AM   #13
GOStang08's Avatar
I have had my Steeda Sport installed since Christmas of 08 and I have not had any problems with it at all. It is smooth and easy to shift.
This is the store I got mine at here in DFW - Mustang Parts & Accessories Superstore - 1800Mustang
The guys up there are very knowledgable and helpful so if you have questions you can give them a call and give them what you are looking for and they can point you in the right direction.
Old 04-10-2009, 02:19 PM   #14
I have a Hurst in my 07 V6. It is way better than stock but not as much of an improvement as I would like. I don't know about the others but the shifts are not as smooth and quick as I would like. The only thing I can compare to is a 66 mustang I put a 4 speed in with a Hurst shifter. could shift that very quickly, so I'm not sure if it's the shifter or the trans.
Mom's - 2007 V6, 5 Speed, Dual Exhaust, CAI, 8.8 with 3.73 gears, Stage 2 Clutch
1965 351C Dragcar Restoration in progress,
1966 289 Pony Restoration in progress
Son's - 2003 V6 4.3L Stroker with lots of goodies,
1965 Dragcar in progress,
1965 Restomod in progress
mxw1090 is offline   Reply With Quote
Old 04-10-2009, 03:01 PM   #15
the Hurst I felt was notchy, my MGW if far superior BUT I have never driven an MGW in an 05+ so who really knows until you try both.
Old 04-15-2009, 11:00 AM   #16
SaleenFiend's Avatar
I was expecting to see some tits.. but after quoting, I realize you were only posting drool smilies
Boo! b/c you were asking for it..
I never liked any of the Hurst I felt especially in the Shelby GTs!
I don't have any exp with the 05+ but I loved the UPR Blue Thunder in my 01 and my brother's Steeda Tri-Ax
Old 04-15-2009, 01:13 PM   #17
I LOVE the hurst shifter in the 05' up ones. its a positive shift and perfect throw for me. its gonna be a matter of opinion. if you see 05' -up owner with aftermarket shifters, ask if you can feel it (
iamdat is offline   Reply With Quote
Old 04-15-2009, 04:07 PM   #18
Yea just go to the local ford dealer and ask to sit in or test drive the 05 Shelby GTs to get a feel for the hurst shifter
Old 04-30-2009, 02:00 PM   #19
jimbullit's Avatar
I have experience with the Pro5.0-on my`03 Cobra-a Hurst on my `03 MaCh1- and my current Hurst-on my fifth gen GT. Because I reused the lower boot-that I salvaged from the stock tower-and wiggled it down over the Hurst-there is zero rattle/ vibration. It shifts nice, looks great. I couldn't be more satisfied. I ordered it from FRPP-through the parts dept. at the dealer-and had it installed by my favorite SVT Tech. Because of how the new tranny is situated-and the fact that he had an electric lift-made it about a twenty minute install. (He had to loosen the tranny bell housing underbrace, and drop the front of the driveshaft, to pull the old one out-you used to just be able to "pull" them off the top of the tranny...) Good Luck!
jimbullit is offline   Reply With Quote
Old 04-30-2009, 02:15 PM   #20
MGW is probably the best but ive yet to drive on eon an 05+
Old 04-30-2009, 04:17 PM   #21
jimbullit's Avatar
Suffice it to say-a much simpler change to either of my two cobras. `Piece of cake in the driveway with the T56-`Not so with the Gen5 cars... That's okay-it looks a little more like a `68 fastback
Old 04-30-2009, 07:47 PM   #22
i want to drive a newer gt/gt500 with a shifter to see how they stack up im sure they are much more sloppy than the previous years thanks to that linkage
Old 05-01-2009, 07:52 AM   #23
jimbullit's Avatar
Nope. Actually, the Pro5.0-on my `03 Cobra was the easier install-but it rattled a little bit-wasn't nearly as quiet as the stock tower. The `08 with the Hurst kicks butt. It is tight, doesn't rattle-at all-thanks in part to the linkage-and re-using the inner boot-from the stock shifter. It works great.
2011 Sterling Gray GT: 5.0, 6speed, Security Pkg., 3:73 Limited Slip,HID headlamps, stripe delete,19" Nickle Luster Wheels, Magnaflow Street Series axle backs
Sold:2008 Vapor GT:Borla Stinger, Hurst, AFM PowerPipe,Velocity MAF,Steeda Underdrive Pulleys, Hyper-Black CS69 Wheels
Old 05-01-2009, 08:08 AM   #24
quite and sloppy are different things, the 05+ with the added linkage can never be as tight as the previous year that has the shifter right ontop of the trans~ its just the way it is
shifter linkage on a toploader with hurst shifter gardgriff24 Classic Mustangs 7 03-02-2009 11:34 PM
Hurst Shifter: Will this one fit? USMCSS 1996-2004 Mustang GT 16 03-18-2007 12:01 PM
WTB: Hurst shifter Ball bullitt482 Mustang Parts for Sale and Wanted 6 03-17-2007 04:50 AM
Hurst short throw shifter Blue232 Pre-2005 V6 Mustang 3 10-12-2003 12:07 AM
03:00 PM
