Brake Problems on a 71 Mach 1 - Mustang Evolution
Old 03-21-2009, 06:25 AM   #1
Region: West Virgina
My rear brakes are not getting any fluid. The front work fine, I bled them and everythings works, so I am assuming the proportioning valve is okay. When I hit the brakes the front resevoir bubbles but when I disconnected the brake line into the rear axle no fluid is present. Any help would be appreciated. Oh yeah, it has power brakes and I have tested it with the engine off.
Thanks
John
71 Mach 1 is offline   Reply With Quote
Old 04-16-2009, 11:10 AM   #2
Mil1ion's Avatar
Send a message via Yahoo to Mil1ion Send a message via Skype™ to Mil1ion
Re: Brake Problems on a 71 Mach 1
Has the car been sitting doing nothing for any length of time ?
My name is Dennis and I approve this message.
Mil1ion is offline   Reply With Quote
Old 04-16-2009, 11:22 AM   #3
yes, for at least 4 years.
Old 04-16-2009, 02:13 PM   #4
SaleenFiend's Avatar
I would check all of the lines to make sure nothing is leaking when going toward the rear. You have a pretty wide spectrum here and I would start with the process of elimination.
Correctly bleed master cylinder: Pull The lines off of the master cylinder and fill the reservoir. Plug one hole in the cylinder with your finger (may need an extra pair of hands to help) and bleed one hole at a time just like you would the brakes until fluid is coming out. Once you have fluid out of the front hole hook up the line. Do the same for the next hole.
If you are able to bleed the master cylinder then it is O.K.
Then follow the lines throughout the vehicle as you check for leaks or clogs. I would remove the lines from the Proportioning Valve and bleed as you did the master cylinder just to check its operation.
I'm no expert on this but I would assume you would want to check all the lines at every point possible to eliminate the area of blockage or failed parts.
Old 04-16-2009, 02:59 PM   #5
Thank a lot for the suggestions, I have bled the front discs and they are fine. I replaced most of the rear lines (except the one that runs the length of the car). I think my problem may be with the "plunger" that is set every time the brake light goes on during start-up.
Old 04-18-2009, 03:19 PM   #6
Mil1ion's Avatar
Because brake fluid absorbs moisture and the car has sat.. IMO, you need to remove the proportioning valve and clean it out or replace it because it has probably has rusted inside.
This is a common theme for cars that sit in a somewhat humid condition.
Old 04-18-2009, 06:54 PM   #7
Thanks, that is a good idea, I think I will pull the valve and clean it thorroughly.
99 35th. ann. GT brake problems !! HELP!! plz j4gwig 1996-2004 Mustang GT 6 06-22-2010 05:28 PM
Brake problems 67mustang97 1996-2004 Mustang GT 4 04-06-2010 06:39 PM
Brake Problems LSUstang Pre-2005 V6 Mustang 9 06-20-2009 05:21 PM
V6 Mustang Brake Booster Problems Brent Pre-2005 V6 Mustang 24 11-05-2007 08:38 PM
mach 1 grille delete problems charkelly9 Mustang Audio & Video 18 08-19-2005 01:25 PM
02:40 AM
