12 volt source in start & crank position - Mustang Evolution
Old 07-02-2009, 10:32 AM   #1
I am doing a efi swap in my 1964 1/2 Mustang and I am having problems with finding a source that gives 12 volts in both the start and crank position.I was trying to use a ignition wire that was hooked up to a stereo but in the crank position it loses voltage. Would I maybe have to tap into the wire directly behind the key ignition switch?
ballajb is offline   Reply With Quote
Old 07-02-2009, 09:12 PM   #2
OsirisGuy's Avatar
Re: 12 volt source in start & crank position
I do not think there is a wire that gives off +12v during crank other then the crank wire. Going into the ignition may solve some problems.
What you also might want to concern yourself with is current as the current behind the radio may not be high enough.
I've never done an EFI swap though so I really don't know what you need a wire for both for.
I hope that helps?
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 07-02-2009, 11:57 PM   #3
RyansQuick6's Avatar
I believe the oil pressure switch may get constant voltage, or you could just tap into the starter relay.
RyansQuick6 is offline   Reply With Quote
Old 07-03-2009, 04:04 AM   #4
OsirisGuy's Avatar
Or how about run a lead straight to the battery then, if you're just looking for a constant.
OsirisGuy is right
2002 Mustang GT
Old 07-03-2009, 10:05 AM   #5
2007STANG's Avatar
Region: West Virgina
i would find them one at a time with the switch off only one will have power thats your main power turn to ACC the the one that just got power is acc then turn to Run (but dont start)thats the one you want then the last one should go to the starter The hard part is to measure them at some times i have nicked the wire enought to see the wire but not cut through GOOD lUCK
Billet fuel door, Daiblo 91 Tune, Xenon ram air hood scoop, MAC performance direct fit headers, 3" 304 SS Dual exhaust, hood pin appearance kit, Red l.E.D. underbody lights, Boy Racer rear wing, Helix power tower plus Throttle body spacer, ventvisor deflector, Aeroform chin spoiler, SVT 18" 9.5 45/255 frount SVT 18" 9.5 40/285 rear trire , GTO rear blackout kit, OEM rear splash guards, Steeda CAI, 8.8 rear axle with 3.73.1 LSD, killer Glass Hose, Smoked Window Louvers by GT Styling 35% Tenting on rear and side windows.
2007STANG is offline   Reply With Quote
Old 07-06-2009, 09:26 AM   #6
Thanks for all the ideas... i am goin to keep on trying because i am ready to get this car started
Chevy Volt Seph The Bar 14 06-07-2008 04:17 PM
AFS wheel source? Tbird232ci Mustang Wheels & Tires 4 11-10-2004 06:12 PM
10:58 PM
