Limited Slip - Mustang Evolution
Old 10-16-2009, 05:38 AM   #1
Limited Slip
Hi,
Well I finally got my engine completed (stock 93 302 bottom, E303 cam, AFR 165 heads, 1.7 ratio rollers, edelbrock RPM intake along with edelbrock 4 barrel, JBA shortie headers, and 4R70W tranny) as far as I think I need to go and now need to look at the rear end. I want to put in a limited slip, ratio between 3.5 and 4.0 (not real hard over on that). I would like ideas or suggestions from anyone that has done, or thinking about doing this mod. Thanks
Forgot the car is a 64 1/2 Conv!
Doug
Rainman64 is offline   Reply With Quote
Old 10-16-2009, 01:11 PM   #2
Re: Limited Slip
what rear does it have? with the power you should be making I would watn an 8.8, and those come with a limited slip already~ I would up the gears ( and rebuild the tlok unit ) with 3.73s or 4.10s if you dont drive it that much.
Old 10-17-2009, 12:24 AM   #3
Re: Limited Slip
Right now it has the stock 3.00. I've been told to get a pre assembled chunk and put it in the original housing. I don't do track stuff, so I don't need the best.
limited slip manic5_2001 2005-2010 Mustang GT 10 04-11-2008 12:01 AM
Posi, T-Lock, Limited slip? fasternu_674 Pre-2005 V6 Mustang 2 10-16-2007 11:23 PM
Limited Slip Differentials SuperItalian Pre-2005 V6 Mustang 6 06-12-2007 03:48 PM
detroit locker vs. limited slip oaktonarcher Pre-2005 V6 Mustang 15 07-10-2004 01:27 PM
06:45 AM
