Ignition key spring return on a 71 Mach 1 - Mustang Evolution
Old 10-25-2009, 04:14 PM   #1
Region: West Virgina
I have a problem with my 71 Mach 1 ignition key lock cylinder. It will not spring back to run when you start it, it stays all the way forward. I had to replace the key lock cylinder and now it has no spring return. There are two bent wire/springs in there. They look like they are the size of paper clips. Anyway, if anyone knows how I can fix this, or where I can get newer return springs, I would appreciate the help.
Thanks
John
jrlg@ymail.com
71 Mach 1 is offline   Reply With Quote
Old 10-26-2009, 08:59 AM   #2
OsirisGuy's Avatar
Re: Ignition key spring return on a 71 Mach 1
Best bet I can currently think of right now is to check a junk yard. If you can get inside the ignition to replace these (or at least compare them) it might give you a better idea on the cause of malfunctioning at least.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 10-26-2009, 02:13 PM   #3
Good thought, if I can find a nearby junk yard with 71-73 Mustang, I will do just that.
Thanks
Old 11-01-2009, 09:06 PM   #4
my 70 was doing the same thing . they have the same ign. try this pul the steering wheel off and at the top of the colum look as you turm the key back and forth there is the steering wheel lock take that philups screw out and the little medal plate out and try a few drops of lite oil in there see if that helps. there is a shaft in there that when u turn the key that works the ign part way down the colum.
putz54143 is offline   Reply With Quote
The return of the 5.0 Mustangfan2003 2011-2014 Mustang GT 31 01-06-2010 11:46 AM
75 Mustang experts please advise reg. Ignition Key. shopcarpro General Mustang Discussion 7 09-14-2009 08:46 PM
Possible Cuda Return JROC General Car Discussion 25 01-18-2007 02:13 PM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
08:23 PM
