67 Mustang coupe value - Mustang Evolution
Old 11-04-2009, 03:54 PM   #1
I have a chance to buy a 67 coupe 289 with GT like interior (full console, speedo/tack gauges). The car is off white with black vinyl top. The car is with its original owner with all original paperwork (title, bill of sale, dealership papers) The car is only dirty and in perfect condition. It appears to only need a major detailing, it has ben just sitting inside a carport in GA. The speedo shows 04037
How can I find out the value of this car?
1enick72 is offline   Reply With Quote
Old 11-04-2009, 04:23 PM   #2
67mustang97's Avatar
Region: Vermont
Re: 67 Mustang coupe value
NADA classic car pricing is where I'd check. Your looking around 7,900. low retail 21,600. high retail. Find out what 289 it has it makes a huge difference in price. Also you say gt like interior? Does it have pony interior (horses on the backs of the seats)?
Old 11-04-2009, 05:08 PM   #3
Can I find that in the vin?
Old 11-04-2009, 06:50 PM   #4
Region: Vermont
you should be able to here is a vin decoder I found for my 67 hope this helps.
Production Numbers:
Standard Convertible: 38,751
Convertible w/Bench Seats: 1,209
Luxury Convertible: 4,848
Standard Coupe: 325,853
Coupe w/Bench Seats: 8,190
Luxury Coupe: 22,228
Standard Fastback: 53,651
Luxury Fastback: 17,391
Total: 472,121
Body Styles: Coupe, Convertible, Fastback
Construction: Unibody Chasis
Available Engines:
200cid 6cyl 1V 120hp
289cid 2V V-8 200hp
289cid 4V V-8 225hp
289cid 4V V-8 271hp
390cid 4V V-8 320hp
Available Exterior Colors
Acapulco Blue Arcadian Blue
Brittany Blue Burnt Amber
Candy Apple Red Clearwater Aqua
Dark Moss Green Diamond Blue
Diamond Green Dusk Rose
Frost Turquoise Lime Gold
Nightmist Blue Pebble Beige
Raven Black Sauterne Gold
Silver Frost Springtime Yellow
Vintage Burgundy Wimbeldon White
Anniversary Gold Aspen Gold
Blue Bonnet Bright Red
Columbine Blue Lavender
Playboy Pink Timberline Green
Vehicle Identification Numbers
Engine Codes
200cid 1V 6cyl 120hp U
289cid 2V V-8 200hp C
289cid 4V V-8 225hp A
289cid 4V V-8 271hp K
390cid 4V V-8 320hp S
7 - Last digit of model year
F - Assembly plant (F-Dearborn, R-San Jose T-Metuchen)
01 - Body code (01-Coupe, 03-Convertible, 02-Fastback)
C - Engine Code
100001 - Consecutive unit number
Example: 7F01C100001
Dimensions (1967 Fastback 302)
Wheelbase: 108 in.
Overall length: 183.6 in.
Width: 70.9 in.
Height: 51.8 in.
Shoulder room: 53.4 in.
Rear seat hip room: 40 in.
Door opening width: 42.2 in.
Floor to ground height: 9.7 in.
Capacities (1967 Fastback 302)
Luggage space, cu. ft.: 5.1
Fuel tank: 17.0 gal.
Crankcase: 4.0 qt.
Radiator coolant: 20.5 qt.
Wheels and Tires (1967 Fastback 302)
Wheel size: 14 x 6 JK
Optional size available: 14 x 5.5 JK
Bolt no./Circle diameter: 5/4.5 in.
Recommended inflation: 28/28 psi
Capacity rating, total lbs.: 4,950
1967 Mustang Weight ('67 Fastback 302)
Curb weight: 3,400 lbs.
Weight distribution, % f/r: 58,42
1967 Mustang Prices Retail
2dr Hardtop, 65A $2,461.46
Convertible, 76A 2,698.14
2+2 Fastback, 63A 2,592.17
289ci 200hp V-8 105.63
289ci 225hp V-8 158.48
289ci 271hp V-8 (with GT Equipment Group Only) 433.55
390ci 320hp V-8 263.71
Cruise-O-Matic automatic transmission, 6cyl 188.18
Cruise O-Matic automatic transmission, 200 or 225hp V-8 197.89
Cruise O-Matic automatic transmission, 271 or 320hp 220.17
4-speed manual transmission, 200 & 225hp V-8 184.02
4-speed manual transmission, 271 & 320hp V-8 233.18
Heavy-duty 3-speed manual, required with 320hp V-8 79.20
Power front disc brakes 64.77
Power steering 84.47
Power convertible top 52.95
GT Equipment Group (with V-8s only) 205.05
Limited slip differential 41.60
Styled steel wheels (2+2 only) 93.84
Styled steel wheels, all others 115.11
Competition handling package (with GT Equip. only) 388.53
Tinted windshield and window 30.25
Convenience Control Panel 39.50
Fingertip speed control (requires V-8 & Cruise-O-Matic) 71.30
Remote control outside mirror (std. 2+2) 9.58
Convertible safety glass rear window 32.44
SelectAire air conditioning 356.09
AM push-button radio 57.51
AM/FM push-button radio 133.65
Stereosonic tape system (AM radio required) 128.49
2+2 folding rear seat and access door (Sport Deck option) 64.77
Full width front seat (NA 2+2) 24.42
Tilt-away steering wheel 59.93
Rear deck luggage rack (2+2) 32.44
Comfortweave vinyl trim (NA convertible) 24.53
Center console (requires radio) 50.41
Deluxe steering wheel 31.52
Exterior decor group 38.86
Lower back panel grille 19.48
Interior Decor Group (convertible) 94.36
Interior Decor Group (all others) 108.06
Two-tone paint (lower back grille) 12.95
Accent paint stripe 13.90
Vinyl-covered roof (hardtop) 74.36
Wheel covers (std. 2+2) 21.34
Interior Trim Code
Black 2A
Blue 2B
Red 2D
Saddle 2F
Ivy Gold 2G
Aqua 2K
Parchment 2U
Black, luxury 6A
Blue, luxury 6B
Red, luxury 6D
Saddle, luxury 6F
Ivy Gold, luxury 6G
Aqua, luxury 6K
Parchment, luxury 6U
Black, bench seat 4A
Parchment, bench seat 4U
Black comfortweave 7A
Parchment comfortweave 7U
Black comfortweave, luxury 5A
Parchment comfortweave, luxury 5U
Old 11-04-2009, 08:21 PM   #5
Wow. Thank you for all the info. This will give me something to do for a while
Old 11-07-2009, 04:29 PM   #6
Region: Vermont
Did you buy the 67? Was it a legit numbers matching car?
Old 11-07-2009, 05:01 PM   #7
I have not bought it yet. The car is very legit. The only thing that has ever been done the car is the wheels have been changed. Is there a way to tell if odometer has rolled over? The odometer shows 04037. Everything looks straight on the numbers. This is deffinately all orig with the original owner
Old 11-07-2009, 05:42 PM   #8
Region: Vermont
Even if the odometer rolled over who cares. It sounds like a good find, my 67 has almost 130k and still runs good. How much are they asking? Don't let this one get away it will just go up in value!
09:07 AM
