Which Power Steering Pump? - Mustang Evolution
Old 02-02-2010, 11:21 AM   #1
Hi,
I’m planning to install the original power steering on my 64 ½ Convertible. I’ve changed the 289 for a 5.0 so I could install a 4R70W transmission. I also converted the front pulleys to serpentine, so I will need a later model pump that has the type pulley. My car has the original air condition compressor, which will make the installing of the power steering pump even more difficult. At a last resort I will remove the compressor (I never use the AC anyway, but it looks good). Any ideas on which pump I should use would be much appreciated. Also, any other guidance would be welcomed. Thanks
Rainman64 is offline   Reply With Quote
Old 02-02-2010, 06:39 PM   #2
Re: Which Power Steering Pump?
Are the late model pumps that would work with your 5.0 for rack and pinion? I don't know if it matters or not. What about pump shaft diameters? Would a serpentine pully fit on an original pump shaft? There's also the hose connections to figure out. I don't know enough to tell you what to do; just stating some things to look into or research before making a decision.
MetallicMist is offline   Reply With Quote
power steering pump replacement 04TRV6 Pre-2005 V6 Mustang 1 03-05-2010 06:18 PM
Winey power steering pump KC5.0 1979-1995 Mustang GT 3 03-28-2009 08:38 AM
Power Steering Pump floridamba Pre-2005 V6 Mustang 4 04-09-2007 04:34 AM
Power Steering Pump Removal Help Justin 1979-1995 Mustang GT 7 03-12-2007 07:24 PM
Power Steering Pump Pulley Kiljosh Mustang Parts for Sale and Wanted 0 06-04-2005 09:57 PM
11:34 AM
