'65 Horn issues - Mustang Evolution
Old 03-18-2006, 11:36 AM   #1
Ken
Ken's Avatar
Region: New Hampshire
'65 Horn issues
The Horn doesn't work on my '65.
After reading through the forums in another site and doing some preliminary trouble shooting, i have a theory on the problem.
The horn ring, held onto the steering wheel by a round plastic piece, with three 'prongs' on it broke, so only two of the prongs grab the steering wheel. This led to the horn ring being lifted by the spring, causing the horn to continuously blow. so they either unplugged something, or the fuse was removed or blew.
The horns work, I jumped them to the battery and all is ok. The steering wheel does not get power though. So something between the battery and horn is disrupted.
I can't get ahold of a manual or schematic which can assist the troubleshooting from here. Anyone know where to look for problems betwen the battery and steering column?
Ken is offline   Reply With Quote
Old 03-18-2006, 12:37 PM   #2
fast64's Avatar
Re: '65 Horn issues
have you tried taking the horn ring off and looking around inside there? all you have to do is twist it and it will come off. My car didn't have horns, but was completely wired up (scared the crap out of me the first time i took the steering wheel off).
GO BRAVES
Old 03-18-2006, 01:29 PM   #3
Ken
Ken's Avatar
Re: '65 Horn issues
Yes, I took the horn ring off. I am not getting the 12v across the contacts, so there is no power getting to that point. Where would the fuse be for the horn?
Old 03-18-2006, 05:45 PM   #4
fast64's Avatar
Re: '65 Horn issues
honestly, i can't tell you, all the wiring thats in my car (minus the engine wiring, that i put in) is hacked to hell, it needs to be redone.
GO BRAVES
Old 04-11-2006, 07:23 AM   #5
Ken
Ken's Avatar
Re: '65 Horn issues
Progress :
The horn ring is held onto the steering wheel by a round plastic piece with three prongs, the three prongs connect to the horn contacts in the steering wheel.
Under the steering wheel is the turn signal switch. It contains the connections for the directional blinkers and two spring loaded connections to touch the horn contacts on the rear of the steering wheel.
The spring connectors can be seen here on the right side, the two pieces sticking up
In my case, the spring connectors on the turn signal switch were destroyed. One was broken off and missing, while the other had fallen off.
There are two wires which connect to the spring connectors and run down the steering column to a 6-port connector under the dash. One is yellow, which carries the 12Vdc and one is blue with a yellow stripe which runs to the horns. The other wires on the 6-port connector are for the directonal indicators.
At this time I have not found any fuse inline with the horn mechanism, but jumping the yellow and the blue/yellow ports on the plug under the dash gets the horn to sound. Extending these up to the steering wheel produces the same result.
I need to buy a new turn signal switch and steering wheel to resolve my problem. It appears that the steering wheel cracked, as usual - which caused the screw holding the slip rings on the back of the steering wheel to become dislodged, and shifted - which closed the circuit and caused the horn to blow. They cut the yellow wire coming from the 6 port connector under the dash to turn the horn off.
Basically the turn signal mechanism is fine, just the entire mechanical assembly under the steering wheel and the horn ring are destroyed. I don't believe the steering wheel can be repaired in a manner which will allow the slip rings to function properly.
New horn ring - $3
New Steering Wheel - $180
New Turn Signal Switch - $45
Total to repair the broken horn - $228
1966 horn button problem theopenroad Classic Mustangs 5 08-18-2008 06:33 AM
How To Hook Up A Horn mustangondubs Pre-2005 V6 Mustang 3 01-31-2008 10:22 AM
01 GT Horn Relay lowering kit 1996-2004 Mustang GT 8 01-10-2008 07:41 AM
Air Horn Fun!!! sctalbott The Bar 6 06-09-2004 11:51 AM
3am fog horn Monkey The Bar 2 08-03-2003 08:00 AM
» Members Mustangs
NQS004
John@NQS
Trudy
Torino
Add your Mustang
08:15 AM
