Can't find the squeeking! 65 Mustang w/swapped out V8 - Mustang Evolution
Old 03-24-2010, 05:35 PM   #1
It's driving me crazy, wife & kids don't like driving w/me...embarressed by the squeeking! 302 V8 inplace of I6, thought it was the I6 worn out suspension...replaced all front end rubber w/new poly & parts (from a-arms to shocks)...new front disc brake kits & new 15" wheels, thought the 14" wire wheels weren't helping the situation. AND, it's only coming from the rightside of the car...sounds & vibrates like loose bolts while driving, but check after check, nothing loose. Please someone out there knows where I can look to fix this without paying top dollar for a mechanic to look at it.
par65 is offline   Reply With Quote
Old 03-25-2010, 12:09 PM   #2
oaktonarcher's Avatar
Send a message via AIM to oaktonarcher
Re: Can't find the squeeking! 65 Mustang w/swapped out V8
turn up the radio?
Delta Sigma Phi
building better men since 1899
You still have a quote in your sig from a guy that hasn't signed in in almost 2 years
www.DeltaArmsCo.com
oaktonarcher is offline   Reply With Quote
Old 03-25-2010, 12:28 PM   #3
Thanks for the suggestion oaktonarcher...the only problem is I haven't installed a radio yet. It's on the list among all the other upgrade wishes.
Old 05-24-2010, 01:43 PM   #4
It sounds like it is only when in motion right? Can you get some frends to push you down the road with the engine off so you can get up close to it and try to locate where it is coming from? Just a thought Kind of getto trouble shooting but some times when you can't find it when it's on the rack you have to get creative. Good luck.
spuds is offline   Reply With Quote
Old 05-24-2010, 06:21 PM   #5
Thanks for the suggestion spuds, but it's really funny, now that the weather has warmed up, the squeeking is gone! I've been told that the new poly-bushings can squeek a while, but it was only one side...weird.
Old 05-24-2010, 09:24 PM   #6
That is great. I am jealous squeak or no squeak that yours is a driver. Mine 71 has been reduced to a rolling chassis at this point. But this year that should change.
Old 05-29-2010, 10:30 PM   #7
Region: Hawaii
you didn't mention if you upgraded to complete and necessary V8 suspension front and rear springs for the extra load. Also the driveline alignment. I6 not designed for V8 load as you probably know and the higher rate suspension is necessary.
66gt350ps is offline   Reply With Quote
00 3.8 mustang parts... difficult to find please help me out here. Black_Sunshine Pre-2005 V6 Mustang 25 03-08-2010 12:27 PM
squeeking noise Warfire80 Pre-2005 V6 Mustang 17 05-26-2007 08:06 AM
Where to find a Turbo kit for a 95 V6 mustang Raiden Pre-2005 V6 Mustang 11 08-01-2006 09:48 PM
belt squeeking Zim 1979-1995 Mustang GT 8 12-07-2005 01:12 PM
waterpump gettin swapped out today Zim 1979-1995 Mustang GT 4 10-03-2005 07:29 PM
10:02 AM
