rack&pinion for 65 ??? - Mustang Evolution
Old 03-31-2010, 06:10 AM   #1
does any one know of a factory rack that can be installed in may 65 with out a major fabrication job without buying a aftermarket kit ??
woody
rwood53 is offline   Reply With Quote
Old 03-31-2010, 12:00 PM   #2
hottcobra's Avatar
Re: rack&pinion for 65 ???
No your going to have a retro fit kit to convert the car to R&P. There are several companies out there that make them. Just have to do a little shoping.
Old 03-31-2010, 01:15 PM   #3
Blogger
Blogger
rickf73's Avatar
Send a message via MSN to rickf73 Send a message via Skype™ to rickf73
Read some post on another forum with someone adding rack to a '66 and this is what he was using.
Total Control Products
It is available in manual or power.
rickf73 is offline   Reply With Quote
Old 12-30-2010, 11:19 AM   #4
I read an article one the net about using an escort rack in one but it didnt say what year it was from
Cziglar is offline   Reply With Quote
Old 01-01-2011, 09:35 PM   #5
ibleedblue65's Avatar
No matter what you will have to build a cross member. Nothing will just straight bolt in. It's a box car so nothing will just bolt in. I could see building your own cross member and picking a good factory rack to save some dough.
ibleedblue65 is offline   Reply With Quote
Old 01-03-2011, 07:47 AM   #6
The cross member would be the easy part the hard part is the tie rods you would have to make an adapter or do like the off road guys do and use a rodent and drill out the spindle for a bolt.
Old 01-03-2011, 07:50 AM   #7
An adapter? The only difficult part about the tie rods would be length and angle. Getting them to fit in the spindle would be easy.
Old 01-03-2011, 08:10 AM   #8
a friend of mine just got a flaming river rack for his 65 vert
Old 01-04-2011, 09:32 AM   #9
Doing the level would be easy just have the weight on the car and mount it level that is how they are mounted in cars that come with them. Length would be a different issue all to together I have seen guys cut the threaded position back and retapped it but I don't know if you would have enough rod to do that
Old 01-04-2011, 10:59 AM   #10
It can be done, but I could see it being a headache when all is said and done. We haven't even touched on the steering shaft. I think if I were to go this route I would consider just doing a full mustang two conversion since it is not much more. That is what I was going to do until I found an adaptor kit for late model cobra brakes on am early car. I think that I will go that route now and either keep the box our eventually build my own kit.
Old 01-05-2011, 07:28 PM   #11
I hear about people using mustang II front end and they the same or better then a fox mustang, whats the deal here?
Dexter is offline   Reply With Quote
Old 01-06-2011, 06:15 PM   #12
People argue over whether the mustang two geometry is better. I don't have any personal experience with it so I really can't say. What I do know is that it makes the rack and bigger brake install easier..
rack & pinion 04TRV6 Pre-2005 V6 Mustang 11 03-08-2010 07:14 PM
Amp Rack at7311 General Mustang Discussion 22 10-31-2008 08:27 AM
Rack and pinion Scut95 The Bar 0 05-11-2008 06:54 PM
Need New Rack-n-Pinion and Suspension... Whats best brand?? superstarjade 1996-2004 Mustang GT 0 03-13-2008 08:09 AM
Rack and pinion Ponycarman Pre-2005 V6 Mustang 13 06-17-2005 06:27 PM
07:46 AM
