Ghia troubles - Mustang Evolution
Old 08-20-2006, 08:22 PM   #1
Ghia troubles
Hey im new to this place and im looking for some info. My 77 Mustang Ghia's signal lights works fine when the heater is off or sometimes when its on low, but turn up the heat and it stops immediately. Im trying to fix it up myself and want to put off having to go to a mechanic for as long as possible. does anyone have an idea about what might be the problem and how i could fix it??
GhiaGirl is offline   Reply With Quote
Old 08-21-2006, 07:26 AM   #2
Re: Ghia troubles
hmm if you can get a wire tester on the wires that power the signals you can determine if they are getting the power they need to turn on. You can pick up a little tester for really cheap, basically its a screw driver looking thing with a light in the handle~ ground the top part of it and stick the power end on a potential "hot" wire and if its hot it will light up.
This may allow you to trace the problem.
o2 and exhaust troubles SVT 1996-2004 Mustang GT 4 11-28-2009 06:50 PM
Exhaust Troubles. Help Please Dark04ShadowV6 2005-2010 Mustang GT 3 05-07-2009 06:21 AM
engine troubles Bill O. 1979-1995 Mustang GT 6 03-15-2008 05:56 PM
01:13 AM
