transmission conversion question - Mustang Evolution
Old 08-21-2006, 06:05 PM   #1
Question transmission conversion question
I am trying to gather up the parts to turn my 1970 mustang from an automatic to a 5 speed manual. Are there any tips that anyone can give me, such as where to find cheap parts. I was also wondering if my current drive shaft would fit a t-5 tranny. any information is appreciated.
shorthairboyman is offline   Reply With Quote
Old 08-21-2006, 06:52 PM   #2
Re: transmission conversion question
im not exactly sure of the length but I doubt it, at least you will have to swap yokes to put the right one on so it will made to the tranny.
Old 08-22-2006, 01:12 PM   #3
fast64's Avatar
what auto is in there? a c4?
GO BRAVES
Old 08-22-2006, 01:20 PM   #4
no its an A.O.D.
Old 08-23-2006, 08:54 PM   #5
Bane-'s Avatar
most likely will need a new exhaust hanger, the driveshaft yoke is the same. why on earth did someone put a aod into a '70?
Old 08-24-2006, 09:55 AM   #6
well supposedly it was the best choice for an automatic overdrive trans but i think it is a terrible piece of equipment and i want to get rid of it. I also wonder if anyone can tell me about the flywheel, my friend has a flywheel out of a 66' motor and it is externaly ballanced. will this work on my 81' motor?
Old 08-24-2006, 09:23 PM   #7
Bane-'s Avatar
also might need a new driveshaft just thought of that. I think as long as its a 50oz imbalance you should be fine as far as the flywheel is concered. Id check around though im not to sure.
Old 08-28-2006, 02:06 PM   #8
also, does anyone know where i could find the actual clutch pedal for a '70 mustang? There is a universal clutch pedal for sale a performance automotive wharehouse, would this work or how hard would it be to make it work?
Old 09-04-2006, 10:03 PM   #9
fast64's Avatar
I bought a manual trans pedal assembly for my 64 on eBay. They are kind of pricey - like $150 for one in good condition, but probably alot better than a universal piece.
GO BRAVES
Old 09-24-2006, 10:05 PM   #10
What is so bad about an AOD?
1968mustang is offline   Reply With Quote
Old 10-12-2006, 05:00 PM   #11
Region: Nevada
MUSTANGS PLUS , MUSTANGS UNLIMITED and NPD , have sections of their catalogs devoted to this swap . I have a T5 in my 70 behind a 351C . i used the bellhousing that came with the trans from an 86 GT . My car had a C4 and the driveshaft was the right length but i had to swap the yoke . One word of caution using the newer style bell housing is that you have to use a 157 tooth flywheel and small starter .one good thing is that the shifter comes right up through the stock hole in the floor .
gasman66 is offline   Reply With Quote
65 mustang generator to alternator conversion question?? donaldva Classic Mustangs 9 10-25-2007 09:27 PM
Transmission Conversion? Shogun232 Pre-2005 V6 Mustang 17 02-21-2007 01:08 PM
Transmission Question Scut95 1979-1995 Mustang GT 1 10-13-2006 09:41 PM
Transmission Question LukeB1034 1996-2004 Mustang GT 1 08-06-2006 09:46 PM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
12:15 PM
