DYNAMO HUM - Mustang Evolution
Old 09-14-2006, 10:05 PM   #1
DYNAMO HUM
Need an expert on this one.
73 mustang convert original owner. 302, 200,000 mi show room condition.
anally maintained.
All of a sudden a vibration at 70 mph.
1. had wheels alligned and ballanced
no change
2. replaced old cast iron wheel break drums
No change
3. replaced carrier berring in diff
no change
4. replace rims and tires
no change
5. ballanced drive shaft no change.
no change
6.replaced trans mounts
no change
This car rides like a vibrator at 70 it's felt in the entire car. What is the matter with this car???
Ray David is offline   Reply With Quote
Old 09-14-2006, 11:43 PM   #2
Re: DYNAMO HUM
:hmm: I'm not an expert, but could it be the bearings, or rubber bushings used in you suspension, and/or motor mounts might be worn out, or maybe some of your steering components might be worn
out. :dunno:
JROC is offline   Reply With Quote
Old 09-15-2006, 12:14 AM   #3
Re: DYNAMO HUM
Already checked everthing it's way beyond that minor stuff
Old 09-15-2006, 07:17 AM   #4
Re: DYNAMO HUM
its not like this would just start one day but have you checked the bushings on the suspension for issue, wear / tear, etc.
Old 09-16-2006, 10:36 AM   #5
fast64's Avatar
Re: DYNAMO HUM
did you check the motor mounts? They are cheap and pretty easy to replace if you can get ahold of an engine lift.
GO BRAVES
Old 09-16-2006, 11:08 AM   #6
bbunt302's Avatar
Re: DYNAMO HUM
It sounds like you've probably already done this too, but go over all the nuts/bolts on your suspension and make sure they are tight (especially the control arms).
Scary stuff.
Old 09-16-2006, 11:09 AM   #7
Zim
You want to **** me?
Zim's Avatar
Re: DYNAMO HUM
U JOINTS!!! Mine started doing this too, and it was the U joint up by the transmission, it was seized up. Check that out.
I like toys
08:27 PM
