What transmission - Mustang Evolution
Old 10-27-2006, 11:36 PM   #1
What transmission
Hey guys,
I have a 66 Mustang with a 302 5.0L 345hp, I need a new transmission and would like something that is high performance what do you recommend and where do you reccommend I buy it?
66dream is offline   Reply With Quote
Old 10-27-2006, 11:44 PM   #2
Re: What transmission
I would recommend a Viper Spec T56, or maybe a TKO 500/600 from D&D Performance if your willing to spend a little bit.
D&D Performance
JROC is offline   Reply With Quote
Old 10-27-2006, 11:51 PM   #3
Thanks, how much horse power can this type of transmission take? Eventually I want to have 650-800 under the hood.
Old 10-27-2006, 11:59 PM   #4
I'm not really sure, but they are some of the strongest manual transmissions you can buy for a Mustangs. If you call D&D Performance they could tell you better than me, they are an excellent transmission company. But I'm pretty sure a Viper Spec T56, or TKO 600 will hold more HP than any other manual trans you can buy.
Old 10-28-2006, 12:02 AM   #5
I do have an automatic, do they also have transmissions for them? As you can see, I want all the performance but I know very little about it. What egine with max hp would you reccomend?
Old 10-28-2006, 12:21 AM   #6
There's several different engines you can make that kind of HP with, but your going to need a really stout engine. I would recommend maybe a stroked 351 windsor with a good sized turbo kit, but their are several engine that could be made to produce those numbers.
Try these company for a really strong engine. I would recommend calling them, and telling them what you want to do with your car, and they will be able to advice you better than me.
CHP short block long blocks engines crate motors
Welcome to DSS Racing.com
Try here for a good Automatic trans.
Performance Automatic
Someone else on here can probably advice you on most of this stuff better than I can.
Old 10-28-2006, 12:25 AM   #7
thanks for the start!
Old 10-28-2006, 10:58 AM   #8
fast64's Avatar
T5's fit better than TKO's and T56's from what I've heard. And I know for a fact that the T5 is only a fraction of an inch longer than the C4 so you don't need to cut your driveshaft, you just need to have a T5 slip yoke put onto it.
GO BRAVES
Old 10-28-2006, 11:15 AM   #9
Jimmy - Thanks. What would type of engine would you recommend? I am looking for 550 hp - 650 hp. Thanks again.
Old 10-28-2006, 11:24 AM   #10
fast64's Avatar
I'd stick with a 5.0 to be honest.
GO BRAVES
Old 10-28-2006, 11:34 AM   #11
bbunt302's Avatar
A stock 302 block will not handle that much power reliably. You could always just buy an aftermarket 302 block... but that seems kinda pointless to me. I'd go with a 351 Windsor stroked out to either a 393 or a 408 with forged internals. Get a nice set of aftermarket heads for it (AFR 205s is what I'd recommend). Then with a fairly small blower making 10-12 psi, you should have no problem hitting 600 hp. It will be a much more reliable engine than the 302 as well.
Scary stuff.
what transmission 67mustang97 Pre-2005 V6 Mustang 2 10-14-2009 08:44 PM
Transmission? fasternu_674 Pre-2005 V6 Mustang 5 12-05-2007 10:42 PM
What transmission do I have???? 1silverstang Pre-2005 V6 Mustang 2 08-26-2006 07:36 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 05:49 PM
Transmission vigiracer Pre-2005 V6 Mustang 2 07-20-2003 02:47 PM
08:27 AM
