What should I look for when buying a 67 stang - Mustang Evolution
Old 11-30-2006, 04:32 PM   #1
Im seriously considering buying a 1967 v8 mustang fastback. Is there anything I should know before buying a classic mustang like this? All I really want it for is for Driving, maybe beef it up with a little more power. Are there any problems that I may have not heard of about the 67 mustang that I should look out for?
Thanks
Justin-Heath is offline   Reply With Quote
Old 11-30-2006, 09:06 PM   #2
rocknbronco's Avatar
Re: What should I look for when buying a 67 stang
look at the body and floor pans for rust or repair and see if its been wrecked and if so try to judge how badly if you can get it in a a lift or jacks and check the bearings in the front by shaking the tires.Look for oil leaks,transmission leaks,radiator leaks,hose leaks and rear end leaks if you can check the condition of all the fluids and look under the dash for signs of bad wiring or jury rigged wires.Give it a drive and see how it rides and stops dont forget the check the tires ofr cupping or feathering.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-02-2006, 11:10 AM   #3
fast64's Avatar
Check the fenders and 1/4 panels behind the tires for rust. Also check the lower doors for rust.
GO BRAVES
Old 12-04-2006, 11:49 PM   #4
t206w6's Avatar
Also check the cowl vent area, passenger side just above the heater/ A/C box, this is usually a good spot for corrosion.
t206w6 is offline   Reply With Quote
Old 12-05-2006, 11:17 PM   #5
fast64's Avatar
^ Thanks, I forgot that. Its almost always a problem on classic Stangs
GO BRAVES
Buying staang Pre-2005 V6 Mustang 8 04-08-2010 06:08 PM
thinking of buying another stang... 04TRV6 General Mustang Discussion 50 02-17-2010 08:46 AM
v6 to true exaust. buying parts. am i buying the right parts steveyb927 Pre-2005 V6 Mustang 4 04-16-2009 11:04 PM
Need help buying rims for v6 stang whitev6stang03 Mustang Wheels & Tires 10 01-03-2005 03:30 PM
Attn Stang Auto stang owners (quick question) Bane- The Bar 7 09-09-2004 12:53 PM
» Members Mustangs
SG
SGwick
Bella
sixpac
Add your Mustang
02:25 PM
