Questions about a 67 mustang? - Mustang Evolution
Old 12-12-2006, 08:07 PM   #1
I have a 67 mustang with a V8 289. It has a 600 cfm edelbrock carburetor and edelbrock intake manifold. Its got a c4 automatic transmission in it. I want to know what i can do to it or put on it to get off the line faster without completely getting horrible milage.
WesR98 is offline   Reply With Quote
Old 12-13-2006, 12:01 AM   #2
Re: Questions about a 67 mustang?
What rear gear ratio does it have in there now?
Old 12-13-2006, 05:12 AM   #3
rocknbronco's Avatar
The easiest and cheapest thing to do it replace your fluids and filters with a high quality fluids and filters I myself use Amsoil lubes so will recomend those.For the Tranny I would say go with Super Shift Transmission Fluid https://www.amsoil.com/storefront/art.aspx and for the rear end I would go with a Severe Gear Synthetic Gear Lube https://www.amsoil.com/storefront/svg.aspx in a 70W90 weight if you have a trac lock then get Slip Loc Differential Addative https://www.amsoil.com/storefront/ada.aspx .For an air filter I would recomend getting a K&N clean out your carb really really well replace the fuel filter to get some cleaner fuel into the compustion chamber and use a good fuel addative yeah Amsoil,here I will just give you the site copy and paste is killing me AMSOIL Corporate - Source of the World's Best Synthetic Lubricants - Motor Oil and Filters ,makes those to also you can go ahead and switch over to a full synthetic oil as well,my good friend and customer run it in his 67 289 with cork gaskets,and got better mileage and lower operational temps thats why I use full snythetic in all my vehicles it reduces the wear and tear and you get a longer service life.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-13-2006, 09:12 PM   #4
alright thats for the responses and i have one more question i forgot. when i burnout only my back right tire spins what can i do to make both spin?
Old 12-13-2006, 10:06 PM   #5
Get a traction lock for your rear end
Old 12-14-2006, 08:56 AM   #6
Weld the spiders if you want to go cheap but make sure its a good weld
Old 12-30-2006, 11:54 PM   #7
gearbanger67's Avatar
Send a message via AIM to gearbanger67
if u want both to spin get a posey rear what im going to invest in mine when i get the money for it best route i think. an stock gears i believe are 2:83s but i might be wrong
gearbanger67 is offline   Reply With Quote
New mustang questions. jaystang13 2011-2014 Mustang GT 9 05-18-2010 08:49 AM
New 08 Mustang Owner with Questions cruss Pre-2005 V6 Mustang 12 12-24-2008 12:22 PM
01 mustang gt questions johns01gt 1996-2004 Mustang GT 5 11-17-2008 08:16 AM
New to the Mustang, I have a few Questions Renegade 800 Pre-2005 V6 Mustang 2 06-19-2008 11:26 AM
New '96 Mustang Owner has questions floridamba Pre-2005 V6 Mustang 4 03-23-2007 02:38 PM
08:17 PM
