A few questions - Mustang Evolution
Old 12-16-2006, 11:19 AM   #1
Send a message via AIM to 70MustangFB
A few questions
Hi,
I have a couple of questions that i am wondering if any of you know the answer too.
First, id like your opinions on what exhaust option i should do. im thinking that i might just run striaght pipes, or glass packs or flowmasters. im not sure what i should do as i dont know how they will sound. if anyone knows how they sound or what sounds best id be happy to hear your opinion.
Second, im more than likely going to be swapping a 460 into the mustang and was wondering what manual transmission would handle the 460 as it will be bored out to around 500-514 cid. I already have a C6 but would like a manual transmission.
If anyone has any answers i would love to hear what you have to say.
thanks
kevin
70MustangFB is offline   Reply With Quote
Old 12-17-2006, 03:54 PM   #2
Re: A few questions
A stock Ford toploader with the 1 3/8 input shaft will work,and duals with a crossover pipe and 2 mufflers(I used Edelbrock Stainless steel) gives a good note.I went with 3 in pipes all the way through.
69boss429 is offline   Reply With Quote
Old 12-19-2006, 12:51 PM   #3
rocknbronco's Avatar
Re: A few questions
For tranny I would go with a TKO600 and for exhaust I would go wit hthe flowmasters.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-31-2006, 12:00 AM   #4
gearbanger67's Avatar
Send a message via AIM to gearbanger67
Re: A few questions
for exhaust id go with the flow masters always a good sounding exhaust and is ussally found on most fords/mustangs
gearbanger67 is offline   Reply With Quote
Old 01-03-2007, 05:54 PM   #5
bullitt482's Avatar
Re: A few questions
I've heard the TKOs were bigger than the T-5's(which is a common swap for the early models). I know in the 64 1/2 to 66 the tunnel has to be worked with to make a TKO to fit. But since the 67-68 can fit an FE and a C6, you should have any problems
Old 01-15-2007, 01:50 AM   #6
Re: A few questions
I did the straight pipe route the first time out.... I drove it home then turned right back around and took it back and put flowmasters on it. Save yourself some gas and put the flowmaster on the first time.
www.superiormustangparts.com
daddiosquared is offline   Reply With Quote
5.0 and 4.6 questions Cblaze 1979-1995 Mustang GT 18 01-12-2011 10:01 PM
I need help with a few questions xjlxking 2005-2010 Mustang GT 14 02-22-2010 01:38 PM
Few questions SaturnMan8227 Pre-2005 V6 Mustang 21 07-10-2008 02:43 PM
Questions cms09071987 Pre-2005 V6 Mustang 14 06-26-2005 12:28 PM
gt take-off questions blk2kconvstang Pre-2005 V6 Mustang 7 03-22-2004 08:02 AM
12:37 AM
