1965 Mustang Chassis alignment questions. - Mustang Evolution
Old 07-14-2010, 10:57 PM   #1
Okay guys,
I am doing some serious work getting the whole front end of my early 1965 Mustang to original spec. I am using George W Liskey's diagram I found on google/yahoo and so far the front end measures up to what the diagram says. The problem is that I ran into fitment issues with my old "sub frame cross member." (The tubular bar that bolts under the engine connecting the driver & passenger side frame rails)
The cross member is about 3/8ths off and am wondering if I should even try to use it again since there is a dent on the bar... a dent like if it would have bottomed out and hit something.
If the chassis is narrower than it should be, what problems other than that cross member not fitting will I have issues with?
Im figuring that Im most likely going to have to get adjustable motor mounts if this is true.
If you have measurements of a sub frame cross member I would appreciate it since it saves me a huge trip to my parts store.
davids65302 is offline   Reply With Quote
Old 09-10-2010, 07:26 AM   #2
justafordguy's Avatar
Re: 1965 Mustang Chassis alignment questions.
This guy knows more about early Mustang alignment than anyone I have ever known. Check out his web site. Give him a call if you really run into trouble. He's a really smart guy when it comes to old Mustangs.
Marlon Mitchell, Owner
Marlo's Frame & Alignment
10225 Canoga Avenue
Chatsworth, Ca. 91311
818-341-0940
Marlon Mitchell, President & Founder
All Mustang & Ford Club of So. Cal.
818-970-2359
All Mustang & Ford Club of Southern California
80 Hatch, 351W, Built C4, 2600 Stall, 8.8 3.73 posi
70 Coupe, 351W, FMX, 8.8 3.25 posi, 4 wheel disks
justafordguy is offline   Reply With Quote
1965 mustang
Alignment Issues bodavenport 1996-2004 Mustang GT 4 12-08-2006 12:45 PM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
03:01 AM
