95 5.0 in a 66 - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Classic Mustangs
Closed Thread
Old 03-31-2007, 06:48 PM   #1
renegade57 is unknown around these parts
95 5.0 in a 66
i just bought a 66 mustang i have a 289 with it i also have a 95 5.0. the trans bolt pattern is diffrent trans bolt pattern if i put in a late model trans in it automatic aod will i have to run any computer control stuff.. also if anyone can recommend any other options let me know. i will also be running a carb not efi.
renegade57 is offline
Old 03-31-2007, 07:07 PM   #2
bluemustang's Avatar
bluemustang is unknown around these parts
Re: 95 5.0 in a 66
talk to Fast64 he'll answer you
bluemustang is offline
Old 03-31-2007, 07:43 PM   #3
fast64's Avatar
fast64 is unknown around these parts
Re: 95 5.0 in a 66
man, go EFI! haha, sorry gotta plug, it rules. I don't know much about the AOD, but I think it is computer controlled. You will also have to get a new crossmember and slip yoke. The non-efi distributors have a different gear and you will need to change out the gear on the cam to match that gear. Let me know if you have any more questions.
GO BRAVES
fast64 is offline
Old 04-01-2007, 03:31 PM   #4
bullitt482's Avatar
bullitt482 is unknown around these parts
Re: 95 5.0 in a 66
The AOD-E which started in 94 is computer controlled. Just go yank one out of 87-93 Fox. Those have the AOD which are not controlled by the computer and have the same bolt pattern as the AOD-E.
01 Bullitt
bullitt482 is offline
Old 04-01-2007, 08:55 PM   #5
Re: 95 5.0 in a 66
thanks for the help
Old 04-02-2007, 03:23 PM   #6
fast64's Avatar
Re: 95 5.0 in a 66
PS, you should still go EFI...............
GO BRAVES
fast64 is offline
Old 04-04-2007, 08:13 AM   #7
Re: 95 5.0 in a 66
i have a frien that has a 351 trans out of a 1990 truck i have not seen it will that bolt to my 95 302 or is it the wrong bolt pattern thanks for all the help
Old 04-04-2007, 08:49 AM   #8
Drnaline is unknown around these parts
Re: 95 5.0 in a 66
90 tranny on a 95 block will work fine.
Drnaline is offline
Old 04-04-2007, 08:57 AM   #9
Re: 95 5.0 in a 66
thank you
Closed Thread
08:38 PM
