will it fit 4.6 in a 66 mustang - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Classic Mustangs
Closed Thread
Old 04-01-2007, 09:00 PM   #1
renegade57 is unknown around these parts
can i fit a 4.6 in the 66 engine bay i have a chance to buy motor and trans for 500 dollars 65k on motor will it fit.
renegade57 is offline
Old 04-02-2007, 10:41 AM   #2
lowflyn is unknown around these parts
Re: will it fit 4.6 in a 66 mustang
It will fit with modifications.
lowflyn is online now
Old 04-02-2007, 10:45 AM   #3
PureVenom is unknown around these parts
I believe it will require some new motor mounts to be fabbed up and I think some fender wall tweaks as well. Other than that, it will go in just fine. I'm trying to remember what the guy had to do on the SN65 project to make the DOHC 4.6 fit....
PureVenom is offline
Old 04-02-2007, 11:05 AM   #4
MarkuzLS1's Avatar
MarkuzLS1 is unknown around these parts
Send a message via AIM to MarkuzLS1
Why not use the 5.0?
Edit: Missed the cheap part...
I like turtles.
MarkuzLS1 is offline
Old 04-02-2007, 11:43 AM   #5
everyone has a 5.0 i just want something different. how much tweaking is needed. and were.
Old 04-02-2007, 11:45 AM   #6
Rollinthundr's Avatar
Rollinthundr is unknown around these parts
I just read some good info about this (4.6 into old mustang). I think it was in this month's HotRod magazine. Check it out. I believe the 4.6 is too wide to fit, but there are some companies that have kits available to help out the process.
Gas, Grass, or Ass; no one rides for free.:beatyou:
1997 Cobra Convertible 1 of 3 made with Crystal White paint, white top, and Saddle cloth interior.
Rollinthundr is offline
Old 04-02-2007, 03:22 PM   #7
fast64's Avatar
fast64 is unknown around these parts
A 4.6....even a 2V..... will not fit between the shock towers on a 64-66. You can get a MustangII style IFS, but they start at about $1200 I think.
GO BRAVES
fast64 is offline
Old 04-03-2007, 12:40 AM   #8
JROC is unknown around these parts
He took a Terminator and put 1966 Mustang body panals on it.
Its build on a Terminator platform.
JROC is offline
Old 04-03-2007, 09:01 AM   #9
I know...but the point is, he made it fit. There are several others that have put the 4.6 in a 65-69 without using the terminator platform...it can be done. I just don't have all the steps they used in front of me.
Old 04-03-2007, 09:45 AM   #10
fast64's Avatar
He could fit the 4.6 because it was still sitting between the terminator shock towers. A 4.6 will not fit between 64-66 shock towers, no matter how much you massage them, if you want a 4.6 you gotta say peace out to the shock towers and hello sawzall.
GO BRAVES
fast64 is offline
Old 04-03-2007, 09:47 AM   #11
Right...which is why I said the fender walls would need some tweaking...I guess I should have said shock towers instead.
All I know is that there are 5 or 6 that I have read about that have stuffed a 4.6L into a 65-69 engine bay. Yes, it took a bit of massaging, but it can be done. It all depends on how ambitious you are.
Old 04-03-2007, 10:04 AM   #12
MarkuzLS1's Avatar
What is the payout from all the work to swap a 4.6L in over a 302 or 351?
I like turtles.
Old 04-03-2007, 10:06 AM   #13
He said earlier, "To be different"....not to mention the complete engine + tranny for $500.
Old 04-03-2007, 10:23 AM   #14
i can also buy a wiring harness for 500 from painless do you think there is a enough room to cut and rework the strut towers or will there be more cutting somewhere else also would the oil pan even fit or would i have to make one
Old 04-03-2007, 03:45 PM   #15
fast64's Avatar
I think the oil pan will fit once you swap over to a Mustang II IFS, I honestly have never seen anyone swap in a mod motor without doing that. You may be able to make a mod motor fit without swapping out the front suspension, but I have never seen it.
Also, I hope it doesn't seem like I keep shooting down your project, I am definitely not, but where is the Painless Ford 4.6L harness? I can't find one on their website. I got the harness for my 5.0L swap from Ford Fuel Injection. It took me about an hour to install, it was a breeze. They have one for the 4.6, and its about $200 more than than 5.0L harness: RJM Injection Tech » 4.6L Telorvek Kits
GO BRAVES
fast64 is offline
Old 04-03-2007, 05:12 PM   #16
bullitt482's Avatar
bullitt482 is unknown around these parts
Exaclty what I was going to say. A LOT of modding. A SOHC longblock is taller AND wider than a big block Ford, i.e. FE and 385 series big block(390/427, 429/460).
01 Bullitt
bullitt482 is offline
Closed Thread
What size rims can fit my mustang? GhostStang Mustang Wheels & Tires 4 07-13-2009 07:58 AM
would a 03 4.6 fit in a 00 mustang 4.6 2kslvrgt 1996-2004 Mustang GT 8 07-03-2009 02:04 AM
Will these tires fit my 2000 V6 Mustang. TEEREX2000 Pre-2005 V6 Mustang 3 11-02-2008 08:19 PM
Will a DELETE Kit fit ne mustang? latinimagexx Mustang Audio & Video 23 02-15-2004 01:37 PM
08:39 PM
