tach ? - Mustang Evolution
Old 04-02-2007, 09:44 PM   #1
gearbanger67's Avatar
Send a message via AIM to gearbanger67
tach ?
yea im still young an getting to know this stuff but here goes, i just mounted my tach in my car an i have it set so when its night or day the tach is lit an i was woundering if that will burn up the bulb in it over time? an also i have a carb prob an when i have car running the tach is steady then it jumps kinda like a spike then settles down again for a few secs then does it again an i was woundeirng if thats a miss or what? sry for all the threads iv been leaving lol
gearbanger67 is offline   Reply With Quote
Old 04-02-2007, 10:08 PM   #2
Re: tach ?
The way my truck is wired is all the interior lights run anytime the truck is running. Haven't had any problems yet and I'm running a triple pod as well as the factory setup.
Old 04-03-2007, 07:29 AM   #3
Re: tach ?
just pop the front area of the dash open and use a power tester (screw driver looking thing that has a wire that you ground then you stick the end of the thing onto a wire if it lights up its a hot wire) and find the wires that are only hot when the lights are on. Then you can use that wire to powre your tach. Just use an inline fuse at least 18 inches or more close to the tach.
Old 04-03-2007, 07:35 AM   #4
Re: tach ?
iv been meaning 2 do that but it was a quick fix so i could of went racing an was j/w if them tach bulbs burn out easy if left on alot, but thnks for the input, an was woundering about the jump in the tach? im having carb probs an im thinkin that might be y but idk im changing plugs an wires tonight to see if that gets it out.
Old 04-14-2007, 07:06 PM   #5
rocknbronco's Avatar
Re: tach ?
thats light should last quite a while maybe even longer than the tach itself.
rocknbronco is offline   Reply With Quote
tach problem cash05_mustang Pre-2005 V6 Mustang 4 10-18-2006 06:16 PM
Installed Tach 98 Gt SilverStang96 1996-2004 Mustang GT 11 02-19-2006 12:08 AM
Tach not working... SilverStang96 Pre-2005 V6 Mustang 3 11-12-2004 11:34 AM
07:02 PM
