Brake pedal return - Mustang Evolution
Old 04-09-2007, 01:24 PM   #1
Question Brake pedal return
My brake pedal recently developed a habit of not returning to its original position after being depressed. It causes my brake lights to stay on and sometimes causes my battery to drain if left on after being parked. I replaced the brake light switch to no avail. Any other suggestions?
Throckmorton is offline   Reply With Quote
Old 04-09-2007, 04:16 PM   #2
MonteCitan's Avatar
Re: Brake pedal return
Is it the brake pedal itself? if you pull up on it, does it return to position... ?
It could be the brake master cylinder is sticking/binding and not allowing it to return all the way
-- Need to know -- year of car/ style of brakes (hydro boost? or were they all vacuum assist back then?)
(it does have power assist brakes, yes?)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-09-2007, 07:28 PM   #3
Yes it seems to be the pedal. It seems to be in a very slight bind at about mid stroke. I can pull it up, and it returns to the correct position. It's a '66
V8, hydrolic drum brakes, no assist. Replaced the master cylinder about 18 months ago. Daily driver.
Old 04-10-2007, 05:53 PM   #4
fast64's Avatar
I was going to say MC, but if you just replaced it, my only guess is pedal also.
GO BRAVES
Old 04-12-2007, 09:48 PM   #5
Region: New Mexico
Kinda seems to me, the pivot bushing on the pedal swing arm might be screwed.
Drnaline is offline   Reply With Quote
Old 04-15-2007, 09:29 PM   #6
Send a message via AIM to 70MustangFB
check to make sure you adjusted the MC rod that connects to the brake pedal assembly right.
70MustangFB is offline   Reply With Quote
The return of the 5.0 Mustangfan2003 2011-2014 Mustang GT 31 01-06-2010 11:46 AM
Clicking sounds when depressed brake pedal jaynez31 New Member Introductions & Greetings 2 11-30-2005 08:01 PM
pedal covers mustangruss Mustang Audio & Video 16 10-27-2005 09:07 PM
01:45 PM
