alignment points - Mustang Evolution
Old 06-03-2007, 11:25 AM   #1
gearbanger67's Avatar
Send a message via AIM to gearbanger67
alignment points
anyone know where the adjustment points are or a site that shows them cause i need to align my 67 an dont know where at...never was good at suspention
gearbanger67 is offline   Reply With Quote
Old 06-03-2007, 09:05 PM   #2
Region: New Mexico
Re: alignment points
I believe the top adjustments are with shims sandwiched between the shock tower the the inner arm mount. And the lower ajustment is a cammed bolt on the inner lower. Also on the lower to adjust it, loosen the nut end and turn the bolt end, shich will move the arm in and out. Hope that helps.
Drnaline is offline   Reply With Quote
Old 06-08-2007, 08:16 PM   #3
thnks doc, i also just read in a mag that a good way to keep alignment good is by puttin a brace in inner wheel well an connet it to bottom of coil over i forget what spot they said but somewhere done there
Old 06-15-2007, 08:09 AM   #4
Region: New Mexico
No thanks needed, Dr. i am not. The long version of my moniker would be aDReNALINE.
shift points for saving gas eddie1 1996-2004 Mustang GT 4 06-03-2009 10:23 AM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
Alignment problem stang-rookie Pre-2005 V6 Mustang 13 06-14-2005 08:35 AM
What the heck are reputation points?! Zim The Bar 15 03-20-2004 04:09 PM
alignment question BlueDonkey Pre-2005 V6 Mustang 5 02-28-2004 08:17 PM
06:12 AM
