93 motor in 1970 Help ASAP PLEASE!!!!! - Mustang Evolution
Old 12-06-2010, 11:54 AM   #1
93 efi 302 motor in my 1970 mustang what needs to be changed other then the oil pan to have this motor running it CARBURaTED. The original motor is coming out just to clean it up and put back in but in the mean time what needs to be done to have the 93 efi motor switched to carburated? help asap
emerson is offline   Reply With Quote
Old 12-06-2010, 12:41 PM   #2
stampde's Avatar
Re: 93 motor in 1970 Help ASAP PLEASE!!!!!
of coarse you have to use your old school distributor( make sure you change the distributor gear to one that can be used with a roller cam ) ,change the intake to carb'd and DON'T forget to change your flywheel if your using your old trans ,you must get the correct after market flywheel to use with your old trans ,if your using the newer trans that came with the 5.0 your good
2011 GT Auto
Old 12-06-2010, 01:51 PM   #3
Thumbs up Re: 93 motor in 1970 Help ASAP PLEASE!!!!!
thanks have new disrtributer didnt know about the fly wheel thanks
Old 12-06-2010, 03:56 PM   #4
stampde's Avatar
not a prob
2011 GT Auto
Old 12-21-2010, 09:05 PM   #5
ibleedblue65's Avatar
Motor mounts, fly wheel, distributor, pan, water pump (depends if you are keeping serpentine or not) a late model pump inlet is on the wrong side for an early radiator. Two pumps are different depths I believe as well. All I can think of. I'm pretty sure the damper is a didn't thickness as well. O and with a rollermotor you need to use a steel distributor gear, a cast iron one will wear quickly.
ibleedblue65 is offline   Reply With Quote
« New to this | 302 »
1970 Chevelle For Sale hottcobra Regional Mustang Discussion 11 04-01-2010 10:29 AM
What is this 1970 Mustang worth? bfgoodmudder Classic Mustangs 7 01-19-2010 11:49 AM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
My 1970 Mach1 video Raytags Pictures and Videos 1 06-03-2008 08:12 PM
1970 Mustang + Sherman tank motor = ????? SilentNoise The Bar 15 04-23-2007 11:32 AM
12:31 PM
