Trans - Mustang Evolution
Old 12-15-2010, 06:41 PM   #1
Trans
Shift kit in a c4 or convert to a AOD Which will be better?
Blackpony is offline   Reply With Quote
Old 12-15-2010, 09:08 PM   #2
Re: Trans
I would only have a aod unless its built, c4 is a good tranny and a shift kit will make it real nice. But this is my own oppinion.
Straublittleman is offline   Reply With Quote
Old 12-19-2010, 09:44 PM   #3
junoS197Bl08's Avatar
Re: Trans
In my opinion I agree with Straub, AOD, but what yr is mustang and what r u runnin?
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 12-21-2010, 08:54 PM   #4
ibleedblue65's Avatar
Depends on what you are doing. If this is a street car and you do a lot of interstate driving then aod, but more than likely that's not the case. I would probably keep the c4, put a shift kit in, and a higher stall converter. Still need to know more about set up though.
ibleedblue65 is offline   Reply With Quote
Old 12-22-2010, 04:41 PM   #5
It's not a daily driver more like a weekend car. It's a c4 now bolted behind a 306 I just want to get a Lil more outta the motor
Old 12-30-2010, 10:31 AM   #6
Re: Trans
I did this conversion to my 67 fastback this time last year, it was most likely the best thing I have done to it so far. The only thing I would say is that it isn't a straight forward swap as u my think, only a few headers fit, u need a speacial cross member, the shift leave has to be changed in the trans, your drive shaft has to be shortened by about 2 in, and the kick down has to be set just right or you will burn up the trans, I had the shop that rebuilt mine set it after I got it in. From a money stand point the shift kit in the c4 will be a lot cheaper, but if you drive it a lot I would go with the aod. I have a 8.8 with 3.73 in it, and it droped my cruise rpm by about 800 to a 1000 rpm. I just don't like the idea of running the engine at about 2500 for and hour or better when Im going some where on it
Cziglar is offline   Reply With Quote
Old 01-01-2011, 09:40 PM   #7
Hence why I said c4. If your not driving it to work daily and taking vacations in it, the c4 is less head ache and less money.
what trans fluid DarkShadows General Mustang Discussion 21 06-14-2009 04:33 PM
00 3.8L trans help!!! jaiveson Pre-2005 V6 Mustang 5 02-21-2009 07:55 AM
New 5.0L Trans. TBone 1979-1995 Mustang GT 0 05-04-2004 08:47 PM
trans am.... lowflyn Pre-2005 V6 Mustang 7 01-06-2004 09:28 PM
Trans Am GT??? .:DarkEntity:. The Bar 10 09-17-2003 03:17 PM
12:44 AM
