Turn signal issues - Mustang Evolution
Old 12-23-2010, 01:16 AM   #1
Turn signal issues
Finally getting my car finished up. New wheels going on tomorrow, and interior shortly. All the lighting on the car works fine, except the turn signals. They orange lights up front come on with the parking lights and flash with the hazards. So do the rear lights. But when I use the turn signal lever nothing happens. Sound more like an issue with the lever, but what do you guys think?
JRodigan is offline   Reply With Quote
Old 12-23-2010, 01:30 AM   #2
Re: Turn signal issues
The hazards are seprate from the turn signals in the fuse box. If you look at your fuse box you will see the turn signal flasher "round metal or plastic thing" and there is one behind the fuse box for the hazards. So you might want to check that.
Straublittleman is offline   Reply With Quote
Old 01-02-2011, 12:20 AM   #3
I'll take a look thanks.
Old 01-03-2011, 06:17 PM   #4
sixty6fastback's Avatar
Look under the glove box in the channel under the dash. Mine has a "flasher" there. I also have one under the headlight switch. I believe one is hazards and one is flashers.
1966 Mustang Fastback HiPo 289 full roller, 4-Speed Toploader,9" w/ 3.70's
sixty6fastback is offline   Reply With Quote
Old 02-28-2011, 09:10 PM   #5
If it isn't the flasher, then consider changing out turn signal switch.
Any problems with brake lights? If so, I would definitely change turn signal switch.
Vin Man is offline   Reply With Quote
Old 02-28-2011, 09:17 PM   #6
bbunt302's Avatar
I had a similar issue once that was due to a loose wire in the back of my headlight switch connector. Took me days to find.
Scary stuff.
Old 03-02-2011, 09:04 PM   #7
Ken
Ken's Avatar
Region: New Hampshire
and it's a very archaic mechanical system in the steering wheel for the turn signals. do you have the original wheel, an OEM replacement, or some aftermarket. I had all sorts of trouble with the slip rings and what not when I replaced my wheel. I would start there before I checked mis-wiring and stuff
Can't afford Mods? Go To College!
Ken is offline   Reply With Quote
LED turn signal bulbs cterie 1996-2004 Mustang GT 1 05-07-2010 11:05 AM
96/04 combo turn signal switch Cobra GT Mustang Parts for Sale and Wanted 1 04-17-2009 09:53 AM
frozen turn signal ceilingguy Pre-2005 V6 Mustang 2 04-10-2009 02:34 AM
turn signal prob gearbanger67 Classic Mustangs 2 10-09-2007 09:37 PM
Sequental Turn signal Discount till the 9th!!! Rellik Mustang Audio & Video 2 11-10-2003 12:04 PM
06:33 AM
