Replacing rear bearing - Mustang Evolution
Old 01-10-2011, 08:26 PM   #1
I have a 65 289 an the rear end outer bearing is worn. Any body have part numbers on all the sacrificial parts I will have to replace? Thanks
Dmay65 is offline   Reply With Quote
Old 01-10-2011, 08:33 PM   #2
ibleedblue65's Avatar
Which bearing are you talking about? Axle bearings? Pinion bearing? Carrier bearings?
ibleedblue65 is offline   Reply With Quote
Old 01-10-2011, 08:48 PM   #3
The outer axle bearing
Old 01-10-2011, 08:53 PM   #4
I'm pretty sure that is just a press on bearing. It is in an 8 inch.
Old 01-10-2011, 08:54 PM   #5
You just unbolt the axle press the old one off and the new one on.
Old 01-10-2011, 09:04 PM   #6
Doesn't it need gaskets and seals?
Old 01-10-2011, 09:09 PM   #7
There its an axle seal but it is not necessary to replace if it is not leaking. If it is an axle bearing, unlike late models where you have to remove the cover, pin and clips, you can just unbolt the axle and remove it.
Old 01-10-2011, 09:17 PM   #8
In the chilton book it shows you have to replace the gaskets cause they get torn, is that true. Thanks for all the help, Dom
Old 01-10-2011, 09:22 PM   #9
If you are careful removing the axle, you should not damage the seal. Why do you know it need an axle bearing? Does it roar? Dies the roar change when you shift the load?
Old 01-10-2011, 09:37 PM   #10
We are pretty positive. At we thought it was the brakes, so we dug in and found the brakes were fine so we rotated to axle and it sounded like a bad bearing but we didn't pull the axle yet because we figured there was no point until we get the parts together and find someone to press it on.
Old 01-10-2011, 10:49 PM   #11
Now we just attempted to pull the car into the driveway an the reserve is clunking and making tons of noise?
Old 01-10-2011, 10:55 PM   #12
Correction rearend not reserve*
Old 01-11-2011, 08:08 AM   #13
Also how do you drain the rear axle on a 65 with 289 5 lug, thank you
Old 01-11-2011, 08:16 AM   #14
Another thing is which 9 inch rear end will fit on a 65 with little to no work, thanks dom
Old 01-20-2011, 07:29 PM   #15
sixty6fastback's Avatar
You can google 65 mustang 9" housing. Should run about $300 or so.
1966 Mustang Fastback HiPo 289 full roller, 4-Speed Toploader,9" w/ 3.70's
sixty6fastback is offline   Reply With Quote
Replacing the rear end Lukesta Pre-2005 V6 Mustang 2 05-21-2010 04:47 PM
Supercharging and replacing rear axle and gears for my mustang 2008 bmx_20055 Pre-2005 V6 Mustang 25 02-07-2009 09:06 AM
Replacing Rear Tail light bulbs SN95 Pre-2005 V6 Mustang 5 02-18-2007 06:05 PM
Pilot Bearing? 19ClearCobra96 1996-2004 Mustang GT 3 04-28-2005 08:16 AM
Best T/O Bearing? 97Stallion Pre-2005 V6 Mustang 2 08-28-2004 04:29 PM
02:23 AM
