Mechanic reccommendations in Nth VA - Mustang Evolution
Old 01-11-2011, 09:48 AM   #1
Sniffa's Avatar
Smile Mechanic reccommendations in Nth VA
Hey all, first time poster in this classic forum
Couple of Q's,
1. I'm after a knowledgable Classic Mustang mechanic in the Vienna, Nth Virginia area. I have a 65 Conv that takes a bit to start, requires quite a few pumps of the accelerator. I'm thinking the Carby may need a O/H, once it starts it purrs like a kitten.
2. The front brakes have been changed to Disc, rear remain standard, however the brake master cylinder is still the orignal. I would like to change it to a dual system. After any recommendations.
TIA.
ID:	22713   Click image for larger version
Sniffa is offline   Reply With Quote
Old 01-11-2011, 02:03 PM   #2
Thegabrielles's Avatar
Re: Mechanic reccommendations in Nth VA
That is a beautiful car!!!! I wish I could help you with some suggestions. The carbs on those are pretty easy to rebuild, but adjustng them sometimes takes some experiance.
If I remember right there is a master cylinder that is specific for the disc brakes. I assume you dont have power brakes. We modified my Sisters 66 couple with 4 wheel disc brakes and hydraulic power assist. Thats the way to go if you are looking to mod for best performance. The one thing I have realized is that a stock mustangs performance was decent for the 60's does not compare to todays. Performance being defined as acceleration, braking, and handling. If you are looking to mod for performance there are endless possibilities, but personally if I had that car it would be stock. You will get more looks and comments than any of us ever will with our new stangs.
Awesome car!!!!!!
2011 Roush Stage 2 Convertible Race Red with black stripes, Charcoal Interior
Roush # 11-0306,Roush Front and Rear Brake Kit, Roush Exhaust with Square tips, 20" wheels with Cooper Tires Roush Billet Grille matching lower 3 piece, Matte Black side and top stripes, White Face Gauge cluster, Convertible Light Bar
Purchased 27Dec2010
Thegabrielles is offline   Reply With Quote
Old 01-11-2011, 10:38 PM   #3
Titus Wadicus
svtlx's Avatar
im just drooln
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
baton rouge mechanic? tigercrazy718 Regional Mustang Discussion 10 12-20-2010 11:39 AM
Mechanic school? LuminaV2 The Bar 21 10-09-2009 12:00 PM
S197 mechanic / speed shop marietta, ga for HPDE car? PayDay General Mustang Discussion 0 06-08-2008 01:19 PM
*Attention Marylanders*ISO Good Mechanic Neptuno Regional Mustang Discussion 1 09-05-2004 07:30 PM
01:59 AM
