68 torque box - Mustang Evolution
Old 01-24-2011, 07:02 PM   #1
68 torque box
Has anyone here replaced front torque boxes on a 68 coupe. I'm just wondering if it something I can do myself.
Dexter is offline   Reply With Quote
Old 02-28-2011, 08:06 PM   #2
I believe they are welded in. If you can handle wire feed, you should be able to do it.
Vin Man is offline   Reply With Quote
Old 04-12-2011, 10:50 AM   #3
Shanes0406's Avatar
They are welded in. The weld to the subframe and frame rails that support the motor mounts and the floor pans... They are very much a pain to do. You need to properly support the front end of the car to make sure the car itself doesn't sag at the firewall... I did it in my garage with a cut off wheel, grinding wheel, and an air chisel. It took me about 3 days to do it... But caution, you migh need to do the floor pans and frame rails too... I would buy all three for each side, that way in case you cut threw one or more you won't be stuck. Hope this helps..
289 With 302 heads Bored .30= Edellbrock Performer RPM = Holley 650 Double Pump = Hooker Headers to Flowmaster 55's= 03 Billet Rims = Name a part... Its been replaced.
Shanes0406 is offline   Reply With Quote
Old 04-12-2011, 08:00 PM   #4
Thanks Shane for the advice I'm starting to look for those replacement parts. What should I use to support the front subframe when I do this, and should I lift it up and put stands under it?
Old 04-12-2011, 10:16 PM   #5
Shanes0406's Avatar
I used 6 jack stands. I put two on the rear torque boxes,(if you aren't replacing them) two on the pinch welds next to the front boxes, and two on the forward radiator supports... Just that way the car doesn't sag. Then it may never line up. I would try to drill out the spot welds on the seat mounts too. That way you have a proper alignment tool when reinstalling them. There I slot to take note of. Just take your time and you should be fine... I did it never doing any major work such as that and it turned out fine for me. Good luck
torque Werewolfmage Pre-2005 V6 Mustang 18 02-09-2009 07:42 AM
'69 fastback frame rail/torque box question--with pics helrazr70 Classic Mustangs 2 07-01-2008 07:53 PM
More Torque Bullitt03 Pre-2005 V6 Mustang 12 12-17-2007 06:26 PM
Got Torque? PureVenom Pictures and Videos 5 10-06-2006 02:50 PM
01:29 PM
