Transmission seal replacement - Mustang Evolution
Old 03-07-2011, 05:43 AM   #1
Uncle has a 71 Mach 1 fastback 429. The rear seal in the transmission is broken so there is tranny fluid all over the back of the car after you drive it. Is there an easy less expensive way to do it other than dropping the transmission out and taking it apart etc.. ?
Snowmoose14 is offline   Reply With Quote
Old 03-07-2011, 07:26 PM   #2
Sounds like it needs rear seal and bushings.......don't need to drop to fix.
ktn5 is offline   Reply With Quote
Old 03-07-2011, 07:48 PM   #3
That's what it needs! Awesome! So is it possible to do it myself or is it better for the dealer to do it?
Old 03-07-2011, 10:54 PM   #4
Re: Transmission seal replacement
You need the tools to do this it is a seal and bushing install tool.......dont know if they are available......You can check the bushing play with seal out and maybe it just needs the seal! Good Luck and happy motoring.....K
Old 03-08-2011, 05:35 AM   #5
Ok thanks!!
New U.S. Seal Herbstang The Bar 8 08-07-2008 01:59 PM
'98 Marker Light seal? matthews.stang Mustang Audio & Video 4 05-26-2007 12:18 AM
Tail light seal? 19ClearCobra96 Mustang Audio & Video 13 03-27-2005 09:24 AM
Pinion seal now fixed SpectorV Pre-2005 V6 Mustang 2 01-11-2005 08:19 PM
Got a pinion seal leak... SpectorV Pre-2005 V6 Mustang 18 01-04-2005 09:19 PM
01:23 AM
