Ball joint - Mustang Evolution
Old 03-24-2011, 09:23 PM   #1
Ball joint
For A 66 stallion would you put ball joint on lower arm or buy the whole arm I had bought joint from a seller (C.J.Pony Parts) I can make it work but the pub (manual) say replace the whole then only different it ribbet from factory but were I live is rare for some reason I got the tools but go figure is it safe or so I trash the ball joint
MustangKing is offline   Reply With Quote
Old 03-25-2011, 10:21 AM   #2
SaleenFiend's Avatar
Re: Ball joint
What is rare?
You can get by with just doing the ball joint. Just check the control arm bushings and make sure they don't already need to be replaced. If so, replace the control arm. If not, replace just the ball joint. You can also tac/spot weld the ball joint in there just to be safe if you have the abilities.
Need to replace rear u joint Kingkong707 Pre-2005 V6 Mustang 11 03-23-2011 05:53 PM
Manual steering rack / rag joint? Cobracoupe5 1979-1995 Mustang GT 2 02-02-2011 10:10 PM
Bad ball joints on a 2007 liteboxz 2005-2010 Mustang GT 1 08-28-2009 09:48 AM
volley ball olympics..**WW** V6STANG007 The Bar 5 08-22-2004 06:19 PM
stangBAYsix..joint meet feb.22 a1yola Regional Mustang Discussion 0 01-20-2004 01:14 AM
12:03 PM
