Stalling out and back fireing - Mustang Evolution
Old 04-15-2011, 12:20 AM   #1
I just bought my first mustang (1967) and on a cold start it runs great. Once you heat it up and shut it off then try to restart it as soon as you put it in gear it starts to stall out. If you let it sit running for a minute then put it in gear it does run but very ruff and it back fires and bogs out as you give it gas. Like I said though cold it runs great and doesn't over heat while driving in fact I just drove it 70 mph for almost 2 hrs on the freeway with no problems. If did seem to want to back fire a few times if I floored it but otherwise it ran great. Any ideas as stated it's a 1967 mustang straight 6 single barrel carb.
thman00 is offline   Reply With Quote
Old 04-15-2011, 10:05 AM   #2
wereKEV's Avatar
Re: Stalling out and back fireing
Sounds like ignition, or battery issues.
wereKEV is offline   Reply With Quote
Old 04-15-2011, 10:30 AM   #3
Batt is brand new
Old 04-15-2011, 10:35 AM   #4
I would check ignition system first. Cap/rotor/points/condenser.
Sounds like the choke may be sticking also. Possibly carb issues.
Alscobra is offline   Reply With Quote
Old 04-15-2011, 11:34 AM   #5
I just replaced my cap and wires today and still doing it. I will check my carb I was thinking it might be my water pump???
Old 04-15-2011, 07:00 PM   #6
Rewbeez's Avatar
I had that on my 66. I ended up putting a spacer between my intake and my carb to keep the heat out of my carb. It was heating the gas in the carb and ran great on the first Start but if I shut it off and started it a little bit latter the carb was vapor locked and I would have to pump the gas alot to get it going again and flood it out really bad. I few mustang mechanics told me it was a common problem and a spacer changed everything...
Rewbeez is offline   Reply With Quote
Old 04-15-2011, 07:03 PM   #7
Rewbeez's Avatar
Good luck!!!
Old 04-15-2011, 11:03 PM   #8
Thanks I will try the spacer
Old 04-16-2011, 04:43 AM   #9
Rewbeez's Avatar
I used a phenolic carb spacer, it is made to lower heat transfer from the intake and carb. It made all the difference in the world for my car. I am using the 1/2" spacer. Make sure you have room between the air cleaner and your hood if you go with a taller spacer.
Old 04-16-2011, 04:28 PM   #10
It sounds like the timing is too far advanced.
Skeezer is offline   Reply With Quote
Old 04-17-2011, 11:11 AM   #11
wereKEV's Avatar
Lightbulb Re: Stalling out and back fireing
yep it sure soynds like timing is off somewhere
Old 04-18-2011, 12:18 AM   #12
Would that only act up when it's hot though, I figured it the timing was out it would do that all the time.
Old 04-18-2011, 08:46 AM   #13
Yes if it was the timing it would do it all the time. Sounds like a carb issue, What size carb vs. motor do you have. If the carb jets are to big then it could be giving to much gas and it wouldn't be a only happens when its hot it would be because when its warming up then its running faster there for burning the extra gas or when you ran 70mph it was burning extra gas. After warming up and its just idling then its feeding more gas then the motor can burn. But Iam just talking from my own situations so hope it helps you.
1966stang is offline   Reply With Quote
Old 04-18-2011, 03:28 PM   #14
I think your right I drove it today and I could really smell gas as I was driving so I think it is the carb too.
5.0 fireing order prive 1979-1995 Mustang GT 2 12-28-2008 05:37 PM
03 GT engine stalling midgeorgiastang 1996-2004 Mustang GT 5 02-22-2008 05:38 PM
stalling 5.0 vil8er New Member Introductions & Greetings 0 02-16-2008 02:12 PM
stalling 94 gt wmustanggt 1979-1995 Mustang GT 8 07-02-2006 01:13 PM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
08:39 AM
