Oil pan change out? - Mustang Evolution
Old 04-16-2011, 06:00 AM   #1
Rewbeez's Avatar
Oil pan change out?
I have a 66 with a 289, how hard is it to change out the oil pan without removing or raising the engine? Are there any tricks or tips on this?
Rewbeez is offline   Reply With Quote
Old 04-16-2011, 06:54 AM   #2
stampde's Avatar
Re: Oil pan change out?
wow , been a long time since i worked on an old 'Stang
I THINK YOU JUST HAVE TO JACK THE ENGINE UP as high as you can get it , front sump if i remember right ?
2011 GT Auto
Old 04-16-2011, 07:05 AM   #3
Rewbeez's Avatar
You are correct it is a front sump... If I raise the engine up as high as I can were is it safe to put the jack ?
Old 04-16-2011, 07:15 AM   #4
stampde's Avatar
wow, dont know what you have ?
i usually use blocks of wood if you dont have an engine hoist ,witch is the best way to do it ... just put the wood on the jack and lift up on the harmonic balancer , not a lot of room to get the pan out then as I'm sure the the jack will be in your way ... just be careful ........ but if you can get an engine hoist just lift it up with that , after you unbolt the engine mounts of coarse
2011 GT Auto
Old 04-16-2011, 07:44 AM   #5
Rewbeez's Avatar
Hahaha. I will use a friends engine hoist. Thanks for your advice....
Old 04-16-2011, 09:50 AM   #6
wereKEV's Avatar
Thats the best way to do it, good luck.
wereKEV is offline   Reply With Quote
Old 04-16-2011, 11:30 AM   #7
Titus Wadicus
svtlx's Avatar
definatley use the engine hoist. i dont advise anyone to lift up a motor by the crank/balancer. itsa quick way to flat spot bearings
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-16-2011, 11:38 AM   #8
wereKEV's Avatar
Ahmen to that!
Old 04-16-2011, 12:37 PM   #9
Rewbeez's Avatar
See those are the tips that are good to know before u start the project !!!! This app rocks !!! Thanks for the advice
Old 04-16-2011, 01:30 PM   #10
stampde's Avatar
as far as flat spotting the bearings , i highly doubt it , your not hammering or beating on the crank your putting a little pressure ... but ya that would only be as a last resort , sometimes you have to make due with what ya got .....
2011 GT Auto
Old 04-16-2011, 07:20 PM   #11
You really should life the engine. I did the same project on my 66 and the cross bar got in the way. I had to keep turning the engine so the pistons would move in the best position to get the oil pan in. It was a project and because of all the manuvering of the oil pan, my gasket moved out of position and I had a bad oil leak. If you don't hoist your engine, make sure you take off the cross bar.
raiderstang66 is offline   Reply With Quote
Old 04-17-2011, 10:54 AM   #12
wereKEV's Avatar
ya lifting the engine is the best way I've replaced oil pan gaskets a few time and that is the easiest way to do it.
need help removing my oil pan! jkaminski24 1996-2004 Mustang GT 7 08-23-2010 04:54 PM
WTB 01+ Crank pulley and Oil pan ebalderas Mustang Parts for Sale and Wanted 0 01-03-2009 11:06 AM
OIL PAN REMOVAL MR.PEE Pre-2005 V6 Mustang 2 05-01-2008 06:00 PM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 05:14 PM
Punch a hole in my oil pan for my vortech danstang Pre-2005 V6 Mustang 20 07-20-2005 07:28 PM
10:22 PM
