351 bolt up to aod 4 speed auto - Mustang Evolution
Old 05-24-2011, 11:25 AM   #1
Gibby's Avatar
A friend of mine has a 69 mustang with a 302 in it. He was thinking of puttin a 351 in place of the 302 will it bolt to his aod 4 speed automatic?
Gibby is offline   Reply With Quote
Old 05-24-2011, 03:08 PM   #2
Titus Wadicus
svtlx's Avatar
Re: 351 bolt up to aod 4 speed auto
yes.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-24-2011, 03:11 PM   #3
Gibby's Avatar
Cool thanks a lot
Old 06-01-2011, 09:59 AM   #4
That was refreshingly short and sweet
Skeezer is offline   Reply With Quote
Will a GT 5-Speed Bolt up to the V6 mxw1090 Pre-2005 V6 Mustang 10 01-08-2010 09:42 PM
auto to 5 speed swap help? mustangfan9969 Pre-2005 V6 Mustang 2 09-25-2009 06:02 PM
auto or 5 speed dodi Pre-2005 V6 Mustang 7 03-19-2008 07:35 PM
06 gt auto to five speed swap. 06johnny 2005-2010 Mustang GT 4 07-13-2007 05:28 AM
5 speed auto for my 99? I_luv_HP&trq Pre-2005 V6 Mustang 1 08-21-2005 06:23 PM
09:20 PM
